where do i connect the boost guage on a jrsc?
Re: where do i connect the boost guage on a jrsc? (93hb)
It has to come from one of the vacuum nipples on the intake manifold. The ones on the throttle body inlet tube do not see boost since they are located before the compressor.
Sonny
Sonny
Re: where do i connect the boost guage on a jrsc? (Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny »</TD></TR><TR><TD CLASS="quote">It has to come from one of the vacuum nipples on the intake manifold. The ones on the throttle body inlet tube do not see boost since they are located before the compressor.
Sonny
By throttle body inlet tube do you mean charge pipe?
anyways you can make your own source by tapping the charge pipe, or -t- off one of the existing vacuum sources. anything after the turbo and before the head .
I have my timing retard tapped into my charge pipe along with my wg.
Sonny
Re: where do i connect the boost guage on a jrsc? (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid »</TD></TR><TR><TD CLASS="quote">
I have my timing retard tapped into my charge pipe along with my wg.</TD></TR></TABLE>
JRSC is a little different. The boost gauge has to connect to the intake manifold.
Re: where do i connect the boost guage on a jrsc? (JT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JT »</TD></TR><TR><TD CLASS="quote">
JRSC is a little different. The boost gauge has to connect to the intake manifold.</TD></TR></TABLE>
Thats correct, I'm stuck in turbo land so i didn't even think about that fact that the sc is mounted different .....oops thanks for clearing tha up
