How do i wire in two fans?
Old Apr 13, 2003 | 09:02 AM
GraphiteAccord's Avatar
Default How do i wire in two fans?
Ok, soon, i'm going to do the pep boys thing, and get some slim fans, and set them up as pusher fans. My question is, should i get two fans, or one? I only have one now because of no A/C, and this is only one on a full core radiator. Anyways...Should i spring for two fans instead of just one? if so, how do i wire the 2nd one...into the same plug as the first? tia...
Old Apr 13, 2003 | 11:58 AM
LSiTurbo's Avatar
Default Re: How do i wire in two fans? (GraphiteAccord)
i would probably only use one fan and put it on the side of the radiator where the inlet and outlet are. Try to get tehe biggest fan you can fit. If you wanted to run two fans you could just splice them into the same plug. shouldnt be that hard...
meanshyguy
Mar 24, 2009 11:53 AM
j.dizzle
Apr 25, 2007 01:22 AM
Kwuaymaikrup
Apr 4, 2004 07:08 AM
Dan GSR
Sep 22, 2002 12:24 PM
