catchcan or breather filter....
Old Apr 10, 2003 | 10:52 AM
shming123's Avatar
Default catchcan or breather filter....
for turbo cars, which is better to use? a catchcan? or just a breather filter? could i just put a hose on it and route it straight down to the ground?
Old Apr 10, 2003 | 11:32 AM
shming123's Avatar
Old Apr 10, 2003 | 11:34 AM
keebler65's Avatar
Default Re: (shming123)
its times like this that i wish the archive-search worked we've had extensive discussions on this in the past.
basically, if i remember correctly from those threads, your best bet is a closed-system since the PCV system require a vacuum to operate properly. so in otherwords, a catch can would be best.
Old Apr 10, 2003 | 11:49 AM
ludelvr's Avatar
Default Re: (keebler65)
There's a difference between the PCV valve and where most people place that breather filter. I've been enquiring whether or not that place where most people place a breather fliter needs to run in vaccum or not. I know that the PCV valve needs to so you won't need a filter on here, but how bout the nipple that usually connects to the intake piping before the throttle body?
Old Apr 10, 2003 | 12:07 PM
intekragsr's Avatar
Default Re: catchcan or breather filter.... (shming123)
https://honda-tech.com/zerothread?id=331750
This should help
Rasmusm
Feb 2, 2013 12:42 PM
blackccoupe
Jul 11, 2006 04:35 PM
65coupe
Jan 15, 2005 04:51 AM
BoostedSi
Nov 25, 2003 12:35 PM
variable
Nov 22, 2002 10:15 PM
