S-AFC hack settings...
Old Apr 10, 2003 | 03:45 PM
diputs's Avatar
Default S-AFC hack settings...
is anyone using the s-afc for the hack? (as opposed to the v-afc) If you are, could you post all your settings. I'll be using them as my baseline setup with some DSM 450's till I can get to the dyno...what do you guys set your low/hi at? Mine's at the factory default 10/50 I believe. What should it be set at? If I set my low and high settings equal, would it matter? Thanks if anyone replies.
..I know this might be a repetitive post, but I couldn't find this info in the archive because no one replys with settings. I doubt this post will be different, but I thought I'd give it a shot.
Modified by diputs at 1:02 AM 4/11/2003
Cee_mon
Dec 22, 2005 07:09 AM
DarknessJ
Jun 11, 2005 09:08 PM
redhatchb18
Oct 21, 2003 11:43 AM
