Quick question about Hondata and basemaps.
Old Apr 11, 2003 | 02:21 AM
CalvitoSol's Avatar
Default Quick question about Hondata and basemaps.
When burning basemaps, do you have to set it up for walbro 255 lp/h fp's too? What i mean by this is when Rocket from Hondasaver burned the basemaps, he asked me what i had. I told him that I had a b16a, 450cc's injectors, etc., but I didn't mention the fuel pump because i wasn't planning on running one. i got the fuel pump after i got the Hondata and it seems like the car is running way too rich (and i also rewired the fp w/ a 10 gauge wire).
Old Apr 11, 2003 | 06:51 AM
JT's Avatar
JT
Default Re: Quick question about Hondata and basemaps. (theory48)
There isn't such setting parameter for fuel pump. However, you do need to specify injector size and static fuel pressure. Most likely your static fuel pressure has increased with the high pressure fuel pump. If you have an adjustable fpr, simply set it back to where it used to be.
Old Apr 11, 2003 | 08:14 AM
boosted hybrid's Avatar
Default Re: Quick question about Hondata and basemaps. (JT)
I have witnessed that fuel pressure will increase by 4-5psi with the walboro units. The fuel pressure is around 42-43psi at static.
Old Apr 11, 2003 | 07:24 PM
CalvitoSol's Avatar
Default Re: Quick question about Hondata and basemaps. (boosted hybrid)
will i be able to trim down the fuel w/ the hondata or will i be needing an adjustable fpr? how are b&m units? i was told that you can only raise the fuel pressure and that's not what we want to do right?
Old Apr 11, 2003 | 07:29 PM
PureTeg420's Avatar
you can lower the fuel using hondata, but to adjust idle fuel pressure I would get an adjustable FPR
Engine Management and Tuning
Apr 3, 2013 11:14 AM
calib17a
Apr 21, 2004 11:50 PM
Blackack26
Feb 22, 2004 04:33 PM
PrecisionH23a
Aug 28, 2002 12:32 PM
JMinSi2000
Apr 25, 2002 12:57 PM
