ok to use wd-40 to clean out turbo oil feed/return??
i wanna clean some of the build up crap out of the feed/return flanges, then ill just use an air hose to blow out the compressor, and turbine housings/wheels
Re: ok to use wd-40 to clean out turbo oil feed/return?? (intekragsr)
that woudl work too i guess, just something to get all the crasp out of there!!
Re: ok to use wd-40 to clean out turbo oil feed/return?? (Acura_I-RS)
I would not use wd-40 near any of the seals, maybe if you took out the lines and cleaned them, it'd be a bit safer imo.
I use deodorized kerosene with a little detergent in my parts washer.
Regards,
BigMoose
Regards,
BigMoose
Re: ok to use wd-40 to clean out turbo oil feed/return?? (BigMoose)
wouldnt the brake cleaner or parts cleaner eat up the seals inside more than wd-40??? my turbo is old enough, so i dont wanna make it any worse
