Fuel management question!
Old Apr 11, 2003 | 07:12 AM
BoostedSOHC's Avatar
Default Fuel management question!
I recently purchased the Apex'i Turbo kit for the SOHC engine, and i can't decide on what to do for fuel management. If i should get the apex'i fuel set up ( which consists of missing link, intank fuel pump, and fmu), or some form of the afc hack, or hondata s200??i would only be runing 8 psi on a stock motor. i have no other fuel upgrades either. Any other setups anyone reccomends would help too. thanks.
Old Apr 11, 2003 | 07:16 AM
autoEXturbo's Avatar
Default Re: Fuel management question! (BoostedSOHC)
me personally, I would go hondata. I started off with the FMU setup and could only go to a certain point. With hondata or something like haltech, your possibilities are almost endless. The FMU is nice, but i'm sure you'll want to crank the boost up past 8psi one day.
Old Apr 11, 2003 | 07:18 AM
b16ahybrid's Avatar
I hear the v-afc hack is pretty good (short of standalone)...
I would recomend some sort of fuel controller to "fine" tune the air/fuel ratio.
High flow intank fuel pump and larger injectors...
go hondata if you have the funds....
Old Apr 11, 2003 | 07:47 PM
Del's Avatar
Del
Default Re: Fuel management question! (autoEXturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoEXturbo &raquo;</TD></TR><TR><TD CLASS="quote">me personally, I would go hondata. I started off with the FMU setup and could only go to a certain point. With hondata or something like haltech, your possibilities are almost endless. The FMU is nice, but i'm sure you'll want to crank the boost up past 8psi one day.</TD></TR></TABLE>
word. hondata is tight, ive only had a few chance to play with it but its very user friendly, im getting it in about a month and never looking back
Old Apr 11, 2003 | 07:49 PM
PureTeg420's Avatar
hondata for sure. AFC hack and FMU are cheap bandaids. Do it right the first time, that way you won't be tearing your motor apart before summer.
Old Apr 11, 2003 | 10:45 PM
intekragsr's Avatar
the reason I am getting a new motor is because I was using the FMU. Go hondata. Seriously, invest a little more money, do it right the first time and you wont be sorry.
You are getting yourself into a money pit, and if you decide to skimp on the most important part of any engine pushing high numbers, you will be digging a deeper grave.
Old Apr 11, 2003 | 10:46 PM
TurBoXBirD16's Avatar
if it's for 8 psi, i would go with the hondata...
you can always sell it later if you decide for something else...
nice kit you got !
good luck
Sassafrass
Mar 3, 2004 11:14 AM
Bictorious
Feb 16, 2004 09:36 AM
threatcon13
Oct 28, 2003 09:13 PM
BoostedSOHC
Apr 11, 2003 02:49 PM
KStuned
May 15, 2002 03:05 PM
