Needed: Hondata/Standalone users with wideband results
If you have a hondata or a standalone, and have wideband results from either dyno sessions or an in-car sensor, I need your input. If you don't fulfill these requirements, thanks for reading.
I need the following:
-Boost Level
-Fuel pressure at Specified Boost
-Injector Pulsewidth or Injector Duty Cycle at every RPM on wideband chart
-Wideband reading at each IDC/IPW
-RPM of each reading
Basicially, what I need to do is be able to see the actual mass flow rate of fuel at a certain rpm, and the A/F ratio at that rpm. And then, I need this for as many rpm's as possible.
Thanks!!
-Boost Level
Thanks!!
