will this turbo support me
Old Apr 12, 2003 | 07:14 AM
RudeLude's Avatar
Default will this turbo support me
will a t3/t04e with a 60 trim and .63a/r support about 450 whp. its goin in a 4g vtec prelude.
thanks
dan
Old Apr 12, 2003 | 07:37 AM
civicudesire's Avatar
Default Re: will this turbo support me (RudeLude)
yeah im preety sure that turbo is good till 450 and then its taping out..........
Old Apr 12, 2003 | 05:03 PM
RudeLude's Avatar
Default Re: will this turbo support me (civicudesire)
anyone else got anyhting to say?
dan
Old Apr 12, 2003 | 05:05 PM
DLB1994's Avatar
yeh it will hold 450whp but i would go with a .82 turbine on a h22
Old Apr 12, 2003 | 07:10 PM
Killa's Avatar
Default Re: will this turbo support me (DLB1994)
no need to go with a .82 housing, just go with the .63 but with a Stage3 wheel, kick in quick and pull hard to redline.
Old Mar 1, 2005 | 06:08 AM
RudeLude's Avatar
Default Re: will this turbo support me (Killa)
i'm goin to be using this turbo with a 10:1 cr, how much power should i be able to put out on about 15psi, and about when should it get full boost?
thanks
daniel
Old Mar 1, 2005 | 06:48 AM
TurboFart's Avatar
with a .63 exhaust wheel you should see full boost at about 43-4700. that turbo will support 450, but it will be breathing heavily
Old Mar 1, 2005 | 07:38 AM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">yeh it will hold 450whp but i would go with a .82 turbine on a h22</TD></TR></TABLE>
i think so too
Old Mar 1, 2005 | 10:38 AM
RudeLude's Avatar
Default Re: will this turbo support me (PrettyLude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">i think so too</TD></TR></TABLE>
y so big? wouldnt the .63 spool a little sooner? i want it to spool somewhere between 3600-4000...
Old Mar 1, 2005 | 10:41 AM
wantboost's Avatar
Who is Mr Robot?
if this is one of the new garret t3/t04e's they support 480 crank hp. the older versions that turbonetics sells only support 450-475 so youve pretty much tapped that turbo out, the problem you face at that point is over speeding the turbo and risk having it destroy itself
Old Mar 1, 2005 | 11:45 AM
RudeLude's Avatar
Default Re: will this turbo support me (wantboost)
would a t3/60-1 be a better choice? and what spec? its goin on a stock bore h22a with 10:1 cr, and some head work...
Old Mar 1, 2005 | 12:38 PM
dustin's Avatar
How much do you weigh?
Old Mar 1, 2005 | 12:59 PM
RudeLude's Avatar
Default Re: will this turbo support me (dustin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">How much do you weigh?</TD></TR></TABLE>
i weigh 185lbs sir.... , i'm asking about a turbocharger...
Old Mar 1, 2005 | 01:14 PM
dustin's Avatar
I think it should be able to support you then
Old Mar 1, 2005 | 02:18 PM
RACEPAK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dustin &raquo;</TD></TR><TR><TD CLASS="quote">I think it should be able to support you then </TD></TR></TABLE>
Ha Ha LOL.....
Old Mar 1, 2005 | 08:40 PM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude &raquo;</TD></TR><TR><TD CLASS="quote">would a t3/60-1 be a better choice? and what spec? its goin on a stock bore h22a with 10:1 cr, and some head work...</TD></TR></TABLE>
I think the 60-1 would be a better choice. Just get the .63 ar stage 3 wheel.
I found them from turbochargers.com for 624 shipped. The 60-1 can support about 525-550 crank hp
Old Mar 2, 2005 | 03:47 AM
RudeLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">
I found them from turbochargers.com for 624 shipped. The 60-1 can support about 525-550 crank hp</TD></TR></TABLE>
i looked on their site, but i dont see any 60-1s for the price...
Old Mar 2, 2005 | 04:56 AM
Tinker219's Avatar
It all depends on what your goals for the car are. If youre looking for streetable performance, go as SMALL as possible, while still being able to hit your goal.
If youre going for a peak HP monster, OR, if you have larger plans in the near future, go larger.
Old Mar 2, 2005 | 05:29 AM
wantboost's Avatar
Who is Mr Robot?
i looked on their site, but i dont see any 60-1s for the price...</TD></TR></TABLE>
http://www.turbochargers.com/T...2.htm
EDIT: Shipping might be more since youre on an island
Old Mar 4, 2005 | 06:48 AM
RudeLude's Avatar
about when would a sc61 spool on an h22a? and how much hp are they good for?
Old Mar 4, 2005 | 11:22 AM
PrettyLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeLude &raquo;</TD></TR><TR><TD CLASS="quote">about when would a sc61 spool on an h22a? and how much hp are they good for?</TD></TR></TABLE>
pm chris ricketts, he can tell you all about it
Old Mar 4, 2005 | 02:22 PM
TIGboy's Avatar
I have a t3/t4 57 trim and its a To4B comp housing its good to about 450whp so I think your gonna do fine! good luck
Old Mar 4, 2005 | 08:23 PM
PrettyLude's Avatar
you sure its a B housing, i thought only the 57 trim came with the E housing, as far as i know, i only seen 54 trims with the B housing
yaaj1320
Dec 25, 2006 02:53 PM
kagee
Apr 5, 2006 05:22 PM
Slomies
Jan 10, 2006 10:33 AM
graphic
Jun 21, 2004 01:10 PM
