Need help with N2O setup
Old Dec 22, 2003 | 06:37 PM
Dammit_Dan_954's Avatar
Default Need help with N2O setup
I plan on doing a High compression N2O direct port setup on my motor. I would like suggestions as to what I might need to make sure it doesn't blow up. Please don't comment on how I shouldn't do it. Please help me on how I can make it work. I want to spray anywhere from 80-120 shot.
This is what I have:
-12.0:1 comp b18c1
-cp pistons 11.5:1 for b18c5 (standard bore)
-stainless high comp valves (makes me around 12.0:1 with gs-r head)
-eagle rods
-ferrea dual springs
-crower retainers
-skunk2 IM
-310cc injectors
-msd digital 6 plus
-skunk2 stage 2 cams
-255lph walbro intank
-vafc
Let me know what else I might need and what u would recommend to help me out.
Modified by FastAssEG at 12:34 AM 1/5/2004
Old Dec 22, 2003 | 09:05 PM
Default Re: Need help with N2O setup (FastAssEG)
bump for no response.
Old Dec 22, 2003 | 09:38 PM
Green JDM-R's Avatar
looks like you got it all covered
Old Jan 2, 2004 | 09:30 PM
Dr Drew's Avatar
You might wanna check out some type of progressive nitrous controller.
Old Jan 2, 2004 | 10:34 PM
Default Re: Need help with N2O setup (Dr Drew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Drew &raquo;</TD></TR><TR><TD CLASS="quote">You might wanna check out some type of progressive nitrous controller.</TD></TR></TABLE>
Is that going to be necassary? U mean one that gradually goes to the shot u have it jetted for right?
I will be using a MSD Digital 6 plus due to the nitrous retard feature instead of the MSD SCI.
Old Jan 2, 2004 | 10:44 PM
Dr Drew's Avatar
It basicly pulses the solinoid and progressivly increases the amount of N2O and fuel depending on RPM. Running a 120 shot, I think you should have something to regulate it. Jacob Electronics makes a good one and there are a few others out there. I'm by no means an expert on N2O so as around more and see what everyone thinks...
Old Jan 3, 2004 | 02:47 AM
xtal's Avatar
You're not going to have traction with that setup if you don't go progressive. Not optional IMHO.
Edit:
Make sure to run maybe 2 steps colder plugs.. replace them often.. water wetter wouldn't hurt either. If you're spending all that money, spend another $400 on a wideband O2 so you can keep your money for a little while, and get a EGT while you're at it to check to make sure your expensive valves aren't going out the exhaust manifold..
sidekickcivic
Aug 8, 2010 08:03 PM
blu_ej
11
Jan 22, 2009 12:09 AM
GsR HtCh
Nov 11, 2003 10:19 AM
alex_b
May 12, 2003 06:26 AM
Mi-4Teg2
Mar 10, 2003 04:54 AM
