RevHard Stage II
Re: RevHard Stage II (quikB18B)
Oh see now. On there site I have read that you have to remove a/c, but didn't realize that it's for all 88-91 civic/crx.
I guess I should start to read more carefully.
Thanks
Thanks
Re: RevHard Stage II (VanHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VanHonda »</TD></TR><TR><TD CLASS="quote">I had to remove it on my 00 si. the wastegate more or less will sit on you AC lines. </TD></TR></TABLE>
Did you really, cause I have a 00 si. So you say you have to remove the a/c.........damn.
Re: RevHard Stage II (d_mart)
The way it turned out...the exit for the wastegate is right on the ac, so whenever it opens you are going to be getting exhaust all over that and everything else in front of it. There is def. no room for a dump tube. Good luck
you can run a dumptube and the revhard mani with a/c. Just buy a pusher fan and put on the condensor and remove the stock fan. Then mount the wastegate directly onto the manifold and put you a dump tube on. Thats what I did to mine and it works fine.
Re: RevHard Stage II (Double121)
This is a good point, I didn't try to use a pusher fan, I didnt think there would be room, but again, didn't try it. Hope it works out for ya.
Craig
Craig
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Double121 »</TD></TR><TR><TD CLASS="quote">you can run a dumptube and the revhard mani with a/c. Just buy a pusher fan and put on the condensor and remove the stock fan. Then mount the wastegate directly onto the manifold and put you a dump tube on. Thats what I did to mine and it works fine.</TD></TR></TABLE>
What a push fan? Sorry for the stupid question.
Is a condensor part of the pusher fan? Will the revhard manifold and tial wastegate on a d16z6 be able to retain a/c without modification or do you have to use a pusher fan? Also, what about a revhard manifold with an internal wastegate?
invisible
41
08-26-2009 09:35 AM
hondamonkey
26
05-16-2005 02:55 PM
