aftermarket fpr?
Old Dec 23, 2003 | 09:42 PM
CaptainMorgan's Avatar
Default aftermarket fpr?
is there a need for a fpr if i just get bigger injectors. I am also going to run hondata. I was thinking about running 780 with fpr, now maybe bigger and not run a fpr. Or is the fpr there for tuning. If its there for that, then wouldn't hondata take care of it.
Old Dec 23, 2003 | 11:06 PM
ndogg's Avatar
Default Re: aftermarket fpr? (doubler)
no engine management system can control fuel pressure. you don't need it but it will aid in tuning.
Old Dec 23, 2003 | 11:11 PM
FredoSP's Avatar
I have one for sale, brand new. I'll give you a good price on it, check sig.
Old Dec 23, 2003 | 11:38 PM
TeStUdO's Avatar
You wont need an adjustable FPR if you are gonna run Hondata and run power within the means of the injectors. The FPR can help if you need to :cheat" a little and raise fuel pressure at idle to make up for smaller injectors. It all depends on your goals.
Old Dec 25, 2003 | 06:38 PM
Default Re: (TeStUdO)
So instead of running the 780 with fpr. I can run 1000 cc and run it at a lower duty cycle. Am i right? I think this will be cheaper instead of buying two things "injectors and fpr" then just buying the bigger injectors.
Old Dec 25, 2003 | 09:51 PM
ndogg's Avatar
Default Re: (doubler)
how much power do you plan on making? the stock fpr can become a bottle neck. 1000cc is getting pretty extreme unless you are going to make really high numbers.
GSROWNSU
Feb 4, 2007 09:17 PM
boostin92hatch
Sep 21, 2006 05:19 AM
GT-KiLLa
Mar 2, 2004 09:53 PM
TurboJesse
Aug 27, 2003 07:27 AM
skrewdlude
Aug 6, 2002 12:56 PM
