EXHAUST
Old Dec 24, 2003 | 07:32 AM
mipawi's Avatar
Default EXHAUST
what exhaust systems are most of you guys using. if you use the 3 inch does it work with the stock catalytic converter or do you have to replace or modify let me know your different thoughts and what exhaust is good to use i was thinkin with goin with the thermal or the mugen twin loop or the jic magic but let me know
Old Dec 24, 2003 | 07:38 AM
b18bturbo's Avatar
Default Re: EXHAUST (mipawi)
alto of people on budgets are using KTeller8 system on here. It customizable so you can use what ever muffler you want. Some use high po cats from random technologies. Most people however just ditch after they have done there emissions testing. Your other choice is to use a thermal 3" setup or th Greddy PE 2 setup. Thats pretty much most of hte 3" exhausts on the market.
Look to pay 250 for DIY setup
and about 550 for built setup
Old Dec 24, 2003 | 07:41 AM
RedTegLS's Avatar
If you are going turbo then you dont want a stock cat. At least get a highflow 3". Thermal or Greddy PE are the best. kteller8 makes nice systems for much less than a thermal but you have to buy a muffler. Still cheaper. I think the twin loop would be too much restriction.
EDIT: damn you beat me to it.....looks like we thought about the same thing though.
Old Dec 24, 2003 | 10:28 AM
mipawi's Avatar
Default Re: EXHAUST (RedTegLS)
cool thanks now do you have to customize the cat converter or does it bolt right up
Old Dec 24, 2003 | 10:37 AM
Hoodwinked's Avatar
I bought my piping for my custom exhaust from kteller8. I also got the 3" magnaflow muffler to go with it. I replaced my stock cat with a carsound 3" high-flow one. I suggest you get the carsound cat. Then just take it to your local muffler shop and they will weld it up for you.
Old Dec 24, 2003 | 11:20 AM
mipawi's Avatar
Default Re: EXHAUST (Hoodwinked)
so you cant use it on your stock cat cause i dont have a turbo yet but i wanted to through a new exhaust on it my engine is done so should i just wait
Old Dec 24, 2003 | 01:28 PM
b18bturbo's Avatar
you cna bolt a thermal 3inch to your stock cat if you want to do that
Old Dec 24, 2003 | 02:36 PM
mipawi's Avatar
Default Re: EXHAUST (b18bturbo)
cool thanks
IgnitionZ055
Sep 6, 2009 07:01 AM
Boostedld9
Welding / Fabrication
Nov 26, 2008 04:47 AM
defnu
Nov 30, 2007 11:32 PM
only1crx
Apr 19, 2004 08:49 PM
mike
Jun 16, 2002 04:44 PM
