Converting HX O2 Sensor To WideBand ?
Old Dec 26, 2003 | 04:29 AM
integlspwr2k's Avatar
Default Converting HX O2 Sensor To WideBand ?
Is it possible to convert my HX O2 sensor so that i can read the airfuel mixture of my motor? I remember vaugly someone on HT doing it, but i'm not 100% sure. I know that the HX/VX comes with a 5 wire o2 sensor which is really Honda's wideband o2 sensor. I know I would have to probally run a display similar to the techedge version but need to know what is needed and how to do it.
Any links to past threads that I can read to do this conversion would be nice.
Thanks In Advance.
Old Dec 26, 2003 | 02:10 PM
Default Re: Converting HX O2 Sensor To WideBand ? (integlspwr2k)
Old Dec 26, 2003 | 05:44 PM
Anyone know?
Old Dec 26, 2003 | 05:58 PM
kamaleon's Avatar
yes you can that o2 sensor its an l1h1 same as what techedge uses so u need a techege controler or any controler that woudl use an l1h1 wB o2 sensor..
other way is to tap into the signal and have it display with a volt meter. (apexi turbo timer comes with built in volt meter.) Memorize a conversion table for 0-5v into afr..
Old Dec 26, 2003 | 06:00 PM
Default Re: Converting HX O2 Sensor To WideBand ? (kamaleon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kamaleon &raquo;</TD></TR><TR><TD CLASS="quote">yes you can that o2 sensor its an l1h1 same as what techedge uses so u need a techege controler or any controler that woudl use an l1h1 wB o2 sensor..
Okay so if i do get the techedge display with the o2 sensor, would I just tap it into the line from the sensor to the ecu?
Need something a little more detailed on the schematics etc.
Thanks!
Old Dec 26, 2003 | 08:14 PM
kamaleon's Avatar
nope.. u need the 'controler box':
O2 L1H1 -&gt; controler box -&gt; WB display
O2 L1H1 -&gt; stoch ecu
cheap way is to tap teh 5v output from teh o2 an dhook it up to a volt meter, then convert that number into afr.
Old Dec 27, 2003 | 05:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kamaleon &raquo;</TD></TR><TR><TD CLASS="quote">nope.. u need the 'controler box':
cheap way is to tap teh 5v output from teh o2 an dhook it up to a volt meter, then convert that number into afr.</TD></TR></TABLE>
thanks. Any past threads that you can link me to show what i need?
Thanks!
Old Dec 27, 2003 | 10:24 AM
kamaleon's Avatar
i ended up using an aem ecu and aem wideband kit.
Old Dec 27, 2003 | 07:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kamaleon &raquo;</TD></TR><TR><TD CLASS="quote">i ended up using an aem ecu and aem wideband kit.</TD></TR></TABLE>
okay soo anyone else know?
Mfoehrkolb
Sep 15, 2011 06:45 PM
4g4drb17
Jun 14, 2004 11:52 AM
righteyeblind
Jan 21, 2004 01:41 AM
Optiks.
Dec 20, 2003 11:09 AM
2000blackgsr
11
Sep 11, 2003 08:33 AM
