A/F Gauge Choices
Old Dec 25, 2003 | 04:43 PM
onePOINTsix's Avatar
Default A/F Gauge Choices
Ok, i've been shoping around for some gauges for my upcoming turbo setup, i was looking for a A/F gauge and theirs SO many to choose from. If i use my stock sensor or better yet, weld in a bung to a different Heated O2 sensor, will it be ok to see a close to correct A/F ratio for driving around town? I dont want to spend the $$$ on a WB O2 meter to drive around town with. Well anyway, i was looking at for a full sweep non LED gauge, like one with a needle thats not a expensive DEFI or GREDDY unit. Or should i just get a LED one... well i dont know, pls vote and give feedback
Old Dec 25, 2003 | 04:47 PM
t04ecvc's Avatar
Default Re: A/F Gauge Choices (Sideout)
A/F gauges in general are just light shows. If you want something that will actually give you the info you need, WBO2 and a EGT would be good things to have.
Old Dec 25, 2003 | 04:49 PM
Default Re: A/F Gauge Choices (t04ecvc)
i know i wish i had the $$$ to dish out for those, unless someone wants to get rid of one for cheep
Old Dec 25, 2003 | 05:27 PM
FCdrifter's Avatar
New User
wideband or EGT guage.
The autometer really is just a light show, it's worthless to tune by. You can tell when your car goes into closed loop mode, and that's about it.
Old Dec 25, 2003 | 05:46 PM
Default Re: A/F Gauge Choices (fcdrifter)
oh well i guess i'll start saving my money then
edit: the point of this thred is that.. Is it ok to use a "light show" for daly driving to tell me if i'm running lean at all
PS the gauge will be on a seprate O2 sensor
Modified by Sideout at 9:57 PM 12/25/2003
Old Dec 25, 2003 | 06:24 PM
t04ecvc's Avatar
Nope, still won't really be effective. There are a few new widebands out there that go for around 300 bux.
Old Dec 25, 2003 | 09:07 PM
Kataku2K3's Avatar
Only wideband
Old Dec 25, 2003 | 10:41 PM
Del_Slowest's Avatar
Default Re: A/F Gauge Choices (Kataku2K3)
damn autometer haters. get the bloody autometer gauge. my works great, i try and keep it in the 3rd rich bar for turbo. you want to have it in the 1st rich bar for N/a applications. BTW i'm at 7psi only
Old Dec 25, 2003 | 11:02 PM
Kataku2K3's Avatar
Default Re: A/F Gauge Choices (Del_Slowest)
Not hating but seriously, you're not going to be able to tune very well with a car on 20lbs.+ (which we do a lot)... If you tuned two identical motors one with a wideband and one with a Autometer/Halmeter especially at higher boost levels which one do you think will make more power... If we're tuning on the dyno we're using the dyno's wideband, in some of our cars with standalones (i.e. F.A.S.T., etc. the wideband output is only displayed on the laptop when we are datalogging or monitoring... Brian's car is tuned at ~12.2:1, but on his Halmeter it reads as rich as it'll go, just saying that they aren't super accurate... Just my $0.02, again
hondaguyexsi
Oct 8, 2005 06:58 PM
madman604
Oct 21, 2003 07:11 PM
nightkid13
May 8, 2003 12:44 PM
Loco Honkey
Nov 10, 2002 10:40 PM
dariusz
May 8, 2002 03:13 AM
