Gm map sensor wiring??? Already searched..
Old Dec 26, 2003 | 11:05 PM
flip1199's Avatar
Default Gm map sensor wiring??? Already searched..
Ok i read all the past treads and looked on Hondata's site but that doesn't really help me any.
My wires coming off the map sensor are white/blue, blue/white, and red/white. I also looked through my helms manual and that didn't help, and i don't have access to a multi-meter. So which wire goes to A,B,and C??
Old Dec 27, 2003 | 12:16 AM
flip1199's Avatar
Default Re: Gm map sensor wiring??? Already searched.. (flip1199)
bump for the late night crew...
Old Dec 27, 2003 | 12:24 AM
pissedoffsol's Avatar
25 Year Member
sorry, i don't have wire colors on me off hand...
Old Dec 27, 2003 | 12:36 PM
flip1199's Avatar
Default Re: Gm map sensor wiring??? Already searched.. (pissedoffsol)
i know where A,B, and C are supposed to go i just can't figure out on my car which is the grd, 5v, and map signal
Old Dec 27, 2003 | 01:07 PM
vtecCJ's Avatar
with key on, take volt meter and find out where 5v is, then switch to resitance setting in Ohms, find out where the ground is, and the third will give some other voltage, but not 5v. I have it wired to my OBD-1 GSR, I'll go look and get you wire color and locations later.
Old Dec 27, 2003 | 01:44 PM
TeStUdO's Avatar
Default Re: (vtecCJ)
I only know the colors for a Civic and Integra. Yours might be the same though.
CIVIC: 1996-1998
Yellow/Red, 5V
Green/White, Ground
Red/Green: Signal to ECU
1994/1995 Integra
Yellow/Red, 5V on B18b engines
Yellow/White, 5V on B18c engines
White/Yellow, Signal to ECU
Green/White, Ground
1996 and later Integras
Yellow/Red, 5V
Red/Green, Signal to ECU
Green/White, Ground
Hope this can help you in some way, if not hopefully you have a multimeter.
Old Dec 28, 2003 | 05:57 PM
flip1199's Avatar
Default Re: (TeStUdO)
anybody know the prelude colors? or what the voltages should be?
Old Dec 28, 2003 | 05:58 PM
TeStUdO's Avatar
Default Re: (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">anybody know the prelude colors? or what the voltages should be?</TD></TR></TABLE>
Do you have a multimeter?
Old Dec 28, 2003 | 06:07 PM
flip1199's Avatar
yup, just went out to home depot and bought one
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecCJ &raquo;</TD></TR><TR><TD CLASS="quote">with key on, take volt meter and find out where 5v is, then switch to resitance setting in Ohms, find out where the ground is, and the third will give some other voltage, but not 5v</TD></TR></TABLE>
Do this then.....................
Old Dec 28, 2003 | 06:51 PM
B18bEK's Avatar
http://www.hondata.com/3barinstall.html
this should help
Old Dec 28, 2003 | 08:35 PM
flip1199's Avatar
Default Re: (B18bEK)
well i got it wired up.
now the only problem is the car shuts off after about 5 secs???
Old Dec 28, 2003 | 08:37 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">well i got it wired up.
now the only problem is the car shuts off after about 5 secs???</TD></TR></TABLE>
I think you wired it up wrong. Put your old map sensor back on and see if it works.
Old Dec 28, 2003 | 08:50 PM
flip1199's Avatar
if my hondata is setup for a stock map, would that make it not run with the 3 bar?
Well on my multimeter one wire read exactly 5v so i connected that to C, then the other read 3.xx so i connected that to B. The last didn't read any volts so i connected that to A
Old Dec 28, 2003 | 09:05 PM
t04ecvc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">if my hondata is setup for a stock map, would that make it not run with the 3 bar?
Well on my multimeter one wire read exactly 5v so i connected that to C, then the other read 3.xx so i connected that to B. The last didn't read any volts so i connected that to A</TD></TR></TABLE>
If the Hondata is setup for stock map, it won't work. The 3bar sends a different voltage out.
Old Dec 28, 2003 | 09:07 PM
TeStUdO's Avatar
Default Re: (t04ecvc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t04ecvc &raquo;</TD></TR><TR><TD CLASS="quote">
If the Hondata is setup for stock map, it won't work. The 3bar sends a different voltage out.</TD></TR></TABLE>
Yeah thats true, maybe someone can hook you up with a 3 bar basemap for now.
Old Dec 28, 2003 | 09:09 PM
t04ecvc's Avatar
If you wired in the 3bar inlin and didn't take off the stock clip, you can interchange until you get your basemap.
Old Dec 28, 2003 | 10:17 PM
Alstare's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t04ecvc &raquo;</TD></TR><TR><TD CLASS="quote">If you wired in the 3bar inlin and didn't take off the stock clip, you can interchange until you get your basemap.</TD></TR></TABLE>
damn good idea, I was just wondering how I was gonna wire up my gm 3bar before driving to get it tuned.
Simple good ideas rock
What was the wire colors for your lude man?
Old Dec 28, 2003 | 10:19 PM
TeStUdO's Avatar
Default Re: (Alstare)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alstare &raquo;</TD></TR><TR><TD CLASS="quote">Simple good ideas rock
Yes they do my...................................PRECIOUS
Soory couldnt resist
Old Dec 28, 2003 | 11:12 PM
Alstare's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">
Soory couldnt resist </TD></TR></TABLE>
lol
I B BANGGIN
Feb 6, 2007 07:50 PM
ZenDynasty
Dec 17, 2006 11:43 PM
spintegra91
Apr 5, 2005 07:50 PM
ProjectLudeSiR
Nov 9, 2003 10:03 PM
xXx Justin xXx
Jun 18, 2003 09:49 AM
