how much boost??? 2000 civic si
Old Dec 22, 2003 | 12:38 PM
importeclipsegst's Avatar
Default how much boost??? 2000 civic si
Hey guys, im a local female racer and im new to forced induction. I have a 2000 civic si turbo, with the following mods, how many pounds will the stock internals handle??? i have it on the stock wastegate settings of 7.8 psi now without it being tuned. It drives nice now but i expected more for $6000 dollars i spent, when i went to Gainesville Speedway it ran a......
R/T........582
60'.........3.107
330........7.347
1/8........10.509
mph.......77.96
1000.......13.193
1/4.........15.412
MPH........101.83
I know my 60ft are SORRY! so u dont have to critisize me on it, but it was untuned and my last run before i found out my motor mounts were all damaged! N/A i ran a 15.5@86????? on the street it pulls so much harder now than N/A. i want to turn up the boost or something but i dont know, maybe you guys can help me out with some helpful advice. with my list of mods what can kinda boost and 1/4 mile times should i expect?
Greddy TDO5H 18G Turbo @ 7.8 PSI(Greddy Kit)
Ported 8cm2 Exhaust Housing
310cc Injectors
Airinx Air Intake
Greddy Type-S BOV
Greddy "BIG" Polished Front Mount Intercooler
Polished Intercooler Piping
Walbro 255LPH Fuel Pump
Jackson Racing AFPR(60PSI-Idle,70PSI Boost)
AEM High Flow Fuel Rail
AEM Fuel Pressure Regulator
Skunk2 Adjustable Cam Gears
NGK R Spark Plugs
Stock Plug Wires
MSD Blaster SS Coil
MSD Modified Distributor Cap
MSD 6AL
Missing Link
Jun Lightened Flywheel
Act 2900 Clutch
Apex-I 2.5 inch SP Cat Back Exhaust
2.5 Inch Custom Down Pipe
Test Pipe
V-AFC Apexi Fuel Computer
Greddy Profec B Boost Controller(Not Even On, Using stock wasgate settings)
Greddy Turbo Timer
Old Dec 22, 2003 | 12:51 PM
gsrhatch530's Avatar
Default Re: how much boost??? 2000 civic si (importeclipsegst)
You just need traction and to get the car tuned.
DA-MAX's Avatar
maybe you just need more practice??
and ouch to $6gs
Old Dec 22, 2003 | 12:55 PM
Racerage1's Avatar
well first off, u kinda need to improve on your driving skills before turning up the boost. im guessing your having traction problems? get better tires and learn how to launch. as far as your engine mods, it looks impressive. but i would suggest maybe a good fuel management system like hondata. or you can do the afc hack(tons of info in the archives). to get the most power, tuning is the key... hope this helps a litlle...good luck and much props on being a female racer. have any pics of the car?
Old Dec 22, 2003 | 01:00 PM
Butcher's Avatar
First off replace those motor mounts, and I suggest hooking up that boost controller. Letting the wastegate control boost sucks. Boost will come on quicker and feel stronger with a boost controller installed.
Secondly, tune it! Asking if you should turn up the boost should come later on down the road. It's not like more boost = better times. Boost can't make up for inexperience at the track. Go practice getting those 60ft's down with a tuned kit, you will be much happier with your car and youself. After that, boost the bitch!
808b18c1boosted's Avatar
try to fix those motor mounts they help with hooking up. also try preloading your trans it helps with my launches and it could save your cv's.
Old Dec 22, 2003 | 01:06 PM
Butcher's Avatar
Default Re: (808b18c1boosted)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 808b18c1boosted &raquo;</TD></TR><TR><TD CLASS="quote"> also try preloading your trans it helps with my launches and it could save your cv's.
Hope she likes eating doughnuts cause that clutch will be glazed!
Old Dec 22, 2003 | 01:13 PM
you gotta know how and when to do it my act 6 puck going strong for a year including street races.
Old Dec 22, 2003 | 01:39 PM
10seceg's Avatar
looks like to me youve got a nice low 13 sec setup and wouldnt worry about 'how much boost' at this point..just put it on some slick and get that driving techniqe down pat..and move on from there.. other than that nice ride
Modified by 10seceg at 5:07 PM 12/23/2003
Old Dec 22, 2003 | 01:50 PM
Civic Power's Avatar
New User
Default Re: how much boost??? 2000 civic si (10seceg)
An Lsd well help ur 60fts with some nice dr / slicks for sure . You need more practices that all
Old Dec 24, 2003 | 08:00 AM
Default Re: how much boost??? 2000 civic si (Civic Power)
ok so when i take it to get tuned at my local dyno, how many PSI should i tune it too? leave it at the stock 7.8 psi from the wastegate? or can with all the other supprt mods that i have can i tune it to lets say around 10psi???
Old Dec 24, 2003 | 08:08 AM
t3to4e's Avatar
ask them or better yet tell them you want to push your car and what would be safe to run psi wise then tune it
Old Dec 24, 2003 | 10:43 AM
fourdoorsleeper's Avatar
boosted si running 15.4? you definitely
need practice
Old Dec 24, 2003 | 10:59 AM
slammin86's Avatar
Default Re: how much boost??? 2000 civic si (fourdoorsleeper)
Your mph should put you in the mid to low 13 range....you just need to learn how to properly launch. Im runnin 10 psi with my vortech kit in my 99 si on stock internals. I also have traction bars and a quaffe, and still have all kinds of traction problems. you just have to learn how to slip the clutch and feather the gas.
I would recomend going ahead and upping the boost to 9 or 10. then get good tires and learn how to drive.
good luck
Old Dec 24, 2003 | 12:07 PM
Default Re: how much boost??? 2000 civic si (slammin86)
thanxs for all your help you guys
jessica
Old Dec 24, 2003 | 12:52 PM
nsxmatt's Avatar
Work on getting the horsepower you got now to the ground then worry about getting more.
Old Dec 24, 2003 | 01:51 PM
InTeGrA B18b1's Avatar
Default Re: how much boost??? 2000 civic si (nsxmatt)
with those 310 injectors, you wont be able to boost that much. Get Hondata with 450's or uberdata, even the vafc hack is better than the sorry greddy fuel management.
also you are trapping 101 thats good should bring you in the mid 13s to low 14's
Old Dec 24, 2003 | 03:45 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importeclipsegst &raquo;</TD></TR><TR><TD CLASS="quote">Greddy TDO5H 18G Turbo @ 7.8 PSI(Greddy Kit)
310cc Injectors
Airinx Air Intake
Greddy Type-S BOV
NGK R Spark Plugs
Stock Plug Wires
MSD Blaster SS Coil
MSD 6AL
Missing Link
Act 2900 Clutch
Test Pipe
Greddy Turbo Timer</TD></TR></TABLE>
Maybe i'm missing something but i don't see anything listed for tuning.
310's and a v-afc? are you adding 50% full once in boost????
First off Get something to actually tune the car with like hondata or even a fmu. (maybe your using the blue box????)
Anyways get it tuned.........................................
Then work on your driving skill...............................
then worry about making more power.........
Tuned @ 7psi you should be making about 220whp good enough to get you high 13's once you get your launch down and get your tires to hook up.
Like it was said before, more boost isn't a replacement for lack of experience...
Old Dec 24, 2003 | 05:04 PM
boosted92's Avatar
Default Re: how much boost??? 2000 civic si (InTeGrA B18b1)
holy ******* 3.1 60 foot!!! THAT is why your times suck for whats done. Learn how to drive before adding more power.
Old Dec 24, 2003 | 05:26 PM
HighPsiAwd's Avatar
your turbo is very capable as you see i'm also running it - tuning goes along ways as does practicing your launch - i wouldn't worry just yet about turning your boost up, it's not the issue. try to get your 60 times down to around 2.2-2.3 and schedule some dyno sessions
ej1252
Sep 10, 2007 10:56 AM
RFd15bhatch
May 16, 2005 04:21 AM
cambopheonix56
Nov 16, 2004 07:40 PM
Memo6453
Jul 2, 2004 03:30 PM
