How much power from a turbo b16a......?
I have a freind that is putting a turbo on his stock b16 powered 94 hatch. What kind of power have you guys seen with a t3/t4e and Hondata on this kind of setup?
Re: How much power from a turbo b16a......? (The Crow)
There are lots of T3/T4's out there. An SC-61 is a T3/T4 and people have made 550+ with that. Theres also smaller T3/T4's like 50, 54, 57 trim available too. There are also many different variables to know what kinda numbers he would put down so we kinda need more info on the setup and what kinda T3/T4 he is running
Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">im running a t3/t4 on a stock b16a, I made 307whp 212wtq, wanted more but my injectors were maxed..</TD></TR></TABLE>
What are the specs on your turbo and how much boost are you running?
Re: (r7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by r7 »</TD></TR><TR><TD CLASS="quote">check signature</TD></TR></TABLE>
Because his b16 is a gen 2, with better cams and a higher CR, I think his numbers should be a little higher than yours. He said he wants about 300hp at 10psi. He plans on running race gas to pull this off.
Re: (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">i was planning on using 550's (was shooting for 350whp) but i had problems with the 550's and had to throw in some DSM 450's.</TD></TR></TABLE>
What was your static fuel pressure set to when you made the 307whp w/those 450's?
What dyno?
Thanks.
What dyno?
Thanks.
Guest
Posts: n/a
Re: (RyanAutry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanAutry »</TD></TR><TR><TD CLASS="quote">
What dyno?
Thanks. </TD></TR></TABLE>
it was a OEM FPR...Dynojet
What dyno?
Re: (Mpir3)
it was a OEM FPR...Dynojet</TD></TR></TABLE>
That's good to know. Do you think my 440's will be good for 285whp w/ stock fuel pressure and high volume pump?
Re: (RyanAutry)
I doubt it.
Once you put a high volume pump your pressure will go up anyway, so it won't be stock fuel pressure. Get a fuel pressure gauge, and get a regulator to set it to whatever.
My guess is 440s will be completely maxed out at that power level.
I doubt it.
Re: (trboCIVICWRX)
May be this will help you out a little.
https://honda-tech.com/zerothread?id=712430
Guest
Posts: n/a
Re: (RyanAutry)
yea, i have a walbro 255hp too...
Vovchandr
01-13-2007 08:34 AM
