Tuning open downpipe.
Old Dec 23, 2003 | 06:53 AM
5thgencivic's Avatar
Default Tuning open downpipe.
Have any of you guys had your car tuned open downpipe? Then later on put on a high flow cat and exhaust? I don't know if I'm going to have the tiime to get my 3" exhaust welded up back from the 3" downpipe. Will I run into problems since the exhaust will richen it up a tad probably? Like hesitation or anything? The car is being tuned with hondata. Thanks.
Nate
Old Dec 23, 2003 | 06:59 AM
TurboLSVtecTeg's Avatar
Default Re: Tuning open downpipe. (5thgencivic)
The only problem i can think of tuning wise, would be the spool up characteristics of the turbo with an open exhaust and with an exhaust. You will have a little bit more lag with a full 3" exhaust compared to just a 3" downpipe. But you will just run a little rich before you start boosting. So unless the car starts bogging out before you hit boost. You could probably lean it out for a couple more hundred rpm before the turbo hits full boost.
Old Dec 23, 2003 | 07:30 AM
Jefnes's Avatar
Default Re: Tuning open downpipe. (TurboLSVtecTeg)
Remember the 'theory' of the honda engine managament, is RPM vs Pressure.
The ecu has no idea of the change in FLOW created by the 'new' exhaust.
The car will run richer if you tune with an open downpipe and swap in
ANY exhaust.
This is a better scenario than tuning with a small exhaust and then running
an open downpipe. (you'll go lean in this case)
My personal opinion is that you'll need a re-tune But, it'll run fine without it.
Jeffrey Atwood
Old Dec 23, 2003 | 07:33 AM
Default Re: Tuning open downpipe. (Jefnes)
Ok, maybe I should try and get it welded up then.. thanks guys.
Old Dec 23, 2003 | 07:48 AM
B18Flip's Avatar
hhmm...so if someones setup is a 3"DP w/ an e-cutout, carsound cat, 3" exhaust. (cutout used for track use) is it better to tune w/ the cut out open? and would there be a substantial difference in the a/f change?
Old Dec 23, 2003 | 08:56 AM
kpt4321's Avatar
Default Re: Tuning open downpipe. (B18Flip)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">would there be a substantial difference in the a/f change?</TD></TR></TABLE>
This is a very difficult question to answer. It depends on the amount of backpressure with the cutout open and closed, and the rest of the setup.
I'd say .5 to 1 points in A/F ratio, but that is a very broad guess.
Old Dec 23, 2003 | 09:10 AM
hulkhb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip &raquo;</TD></TR><TR><TD CLASS="quote">hhmm...so if someones setup is a 3"DP w/ an e-cutout, carsound cat, 3" exhaust. (cutout used for track use) is it better to tune w/ the cut out open? and would there be a substantial difference in the a/f change?</TD></TR></TABLE>
Tune with it open, yes.
Old Dec 23, 2003 | 09:21 AM
B18bEK's Avatar
i tuned with an open 3" dp because i didn't have exhaust yet. now i have a full 3" exhaust and i'm running a little rich. it actually feels better with the exhaust on - with open downpipe there was a huge loss of power in daily driving (before boost). not a big deal either way, i don't have any lag or cutout after adding the exhaust.
Old Dec 23, 2003 | 11:30 AM
Default Re: (B18bEK)
hmmm. decisions, decisions
Old Dec 23, 2003 | 12:12 PM
accordfreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18bEK &raquo;</TD></TR><TR><TD CLASS="quote">i tuned with an open 3" dp because i didn't have exhaust yet. now i have a full 3" exhaust and i'm running a little rich. it actually feels better with the exhaust on - with open downpipe there was a huge loss of power in daily driving (before boost). not a big deal either way, i don't have any lag or cutout after adding the exhaust.</TD></TR></TABLE>
me too.. it feels **** slow before the boost hits with the cutout open
ApexiChild
Sep 21, 2010 10:07 PM
Otis37
Aug 15, 2009 11:55 AM
zach1288
Jan 3, 2009 08:23 PM
bboysake
Aug 13, 2006 12:07 AM
JDM_EH2
Sep 8, 2005 07:59 PM
