Help....strange problem.
Old Dec 25, 2003 | 12:33 PM
b16ahybrid's Avatar
Default Help....strange problem.
I'll start by listing my set-up (relevent parts)
stock b16, 93 gs-r ecu (p-72 i believe) fields sfc vtec fuel controller, rc 310cc injectors, vortec 4:1 fmu, ngk 7 series plugs, msd 6al, crane trc-1 (same as msd btm),magnecore plug wires. I thats all.
The car has been tuned on a dyno so the afr is good. (12:1 to be exact)
Heres the problem, for no apparent reason the car will (while driving normal) lose all power and try dying (would die if i didn't keep reving the engine). When i pull over it won't start, It will try starting but then die. When it's acting this way it smells really rich (lots of unburned fuel).
When the car acts up my air/fuel ratio gauge doesn't work either (fine other times). When the car does this i have to pull over and reset the ecu (by pulling the fuses) and the the car starts rite up and drives fine.???
there is no rhyme or reason to it's madness, nothing prior effects (driving style) seems to have any contribution.
Other then this problem the car runs like a champ. I never drive the car anymore, but this spring I will be racing it a lot more then last summer, and i really don't want to be sitting at the tree and have this happen...
thanks
jesse.
Old Dec 26, 2003 | 02:27 PM
b16ahybrid's Avatar
Default Re: Help....strange problem. (b16ahybrid)
Anybody?
Old Dec 26, 2003 | 02:47 PM
Drew Peacock's Avatar
Have you tried checking the CEL code sounds like your 02 sensor to me??
Edit what are you using to prevent your ECU from seeing boost?????????
Old Dec 26, 2003 | 02:53 PM
RedStarGsr's Avatar
Default Re: Help....strange problem. (turbozxi)
this isnt helping but a 93 gsr ecu is a p61, vtec at 5600 and revlimit at 8000. obd1, no secondaries.
Old Dec 26, 2003 | 02:59 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote">Have you tried checking the CEL code sounds like your 02 sensor to me??
Edit what are you using to prevent your ECU from seeing boost?????????</TD></TR></TABLE>
not yet, but i do need to check that. I was thinking the same thing because of how's it's acting. The thing thats throwing me off is that the problem goes away when i reset the ecu. I would assume that resetting the ecu would have no effect on the o2 sensor (if it was bad)......I guess i just need to check for a cel and see what it tells me...thanks for the reply.
Old Dec 26, 2003 | 03:01 PM
b16ahybrid's Avatar
check valves. But the problem happens even when i'm not boosting, or havent boosted in a while. I'll be driving down the road and it will suddenly happen...
Old Dec 26, 2003 | 03:03 PM
b16ahybrid's Avatar
Default Re: Help....strange problem. (RedStarGsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedStarGsr &raquo;</TD></TR><TR><TD CLASS="quote">this isnt helping but a 93 gsr ecu is a p61, vtec at 5600 and revlimit at 8000. obd1, no secondaries. </TD></TR></TABLE>
sounds about rite.......
anyway to bump the revlimiter?
I have vtec set at 6k (to get rid of the dip in power at the vtec x-oxer)
Old Dec 26, 2003 | 03:08 PM
Yeah check the CEL, thats pretty easy to do. I would change the check valves for a missing link myself.
Old Dec 26, 2003 | 03:14 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote">Yeah check the CEL, thats pretty easy to do. I would change the check valves for a missing link myself. </TD></TR></TABLE>
I never drive the car so once i park it i don't think about it until i drive it or until I think about getting it ready for this spring....
The check valves have been doing fine for me for about 4 years now ......I guess IMO why spend money on something i don't need to. If it aint broke don't try fixing it.... ....eventually when i build the engine i'll switch to hondata and get rid of the piggyback and check valves...
Old Dec 26, 2003 | 03:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">
The check valves have been doing fine for me for about 4 years now ......I guess IMO why spend money on something i don't need to. If it aint broke don't try fixing it.... ....eventually when i build the engine i'll switch to hondata and get rid of the piggyback and check valves...</TD></TR></TABLE>Yeah I hear there unreliable often leaking a little bit of boost causing CELs etc, another thought is your MSD setup it could be a grounding issue. You have been boosted a fair while I remember you from superhonda still post on that Ghey site?
Old Dec 26, 2003 | 03:31 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I hear there unreliable often leaking a little bit of boost causing CELs etc, </TD></TR></TABLE>
Yeah they can stick closed and cause i cel, mines never failed me ...yet .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi, another thought is your MSD setup it could be a grounding issue. [/QUOTE &raquo;</TD></TR><TR><TD CLASS="quote">
It does act like the ecu/ignition is cutting spark to 3 of the 4 cylinders (hence the strong gas smell)......
[QUOTE=turbozxi]You have been boosted a fair while I remember you from superhonda still post on that Ghey site? </TD></TR></TABLE>
Nope, haven't been there in over a year, i tried to log one about a year ago but the site was down, i never went back....
Thanks for the sugestions, i'm just getting some idea's so when i have a little bit of time i can check everything out.....
Old Dec 26, 2003 | 03:35 PM
Thats cool goodluck
Old Dec 26, 2003 | 03:41 PM
b16ahybrid's Avatar
thanks
Old Dec 26, 2003 | 04:11 PM
D-Man's Avatar
I would try another distributor.I was having a similiar problem and that was the culprit.
slowteg90
Feb 18, 2008 12:25 PM
JorgeYaHeard
Jul 25, 2007 08:35 AM
alfee
May 23, 2005 04:30 PM
typerlc
Jan 26, 2004 01:52 PM
