CP Pistons Compression.
Old Dec 24, 2003 | 12:36 PM
b00stedbyFastrax's Avatar
Default CP Pistons Compression.
got this info from a dealer.
89mm stroke with B16 Head = 9.7:1 CR
87mm stroke with B16 Head = approx. .5 pt lower.
what will a GSR head yield with these pistons on a GSR Short block with the 87mm
stroke?
Old Dec 24, 2003 | 12:45 PM
earl's Avatar
Default Re: CP Pistons Compression. (BoostedbyFastrax)
I would need to know what model number piston you are talking about to give you an answer. It would also help to know how thick a head gasket you will be using. I can also give you dome volume numbers for any model. What dealer did you get your info from?
Old Dec 24, 2003 | 01:52 PM
Default Re: CP Pistons Compression. (earl)
earl, spec sheet says shelf part # SC7018 and outside the box is 27566. piston is 84.5mm for gsr block. plan to use .043 cometic hg. got it from a local dealer that says it was supplied from race engineering.
Old Dec 24, 2003 | 02:04 PM
Boostfed's Avatar
New User
9.40:1 with a GSR/ITR stroke of 87.2mm and a .043" Cometic gasket and GSR head approximately. The dome displacement should be approx -6.2cc
Old Dec 24, 2003 | 02:06 PM
earl's Avatar
84.5 mm bore
87.2 mm stroke
41.6 cc chamber b18c head
.043" thick head gasket
-7.2 cc dome volume (SC7018)
.020" piston in the hole
9.44-1 compression ratio
How far down the hole the piston sits will affect this ratio.
to play with combinations, go here
http://www.c-speedracing.com/h...c.php
Old Dec 24, 2003 | 02:08 PM
earl's Avatar
Default Re: CP Pistons Compression. (Boostfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed &raquo;</TD></TR><TR><TD CLASS="quote">9.40:1 with a GSR/ITR stroke of 87.2mm and a .043" Cometic gasket and GSR head approximately. The dome displacement should be approx -6.2cc</TD></TR></TABLE>Very good approximation...who needs a calculator
Old Dec 24, 2003 | 02:09 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">84.5 mm bore
87.2 mm stroke
http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
The LS/GSR/ITR show as .030" piston to deck height. If it is -7.2cc then it will be 9.46:1 CR
Old Dec 24, 2003 | 02:11 PM
Boostfed's Avatar
New User
Also if we do a .030" piston to deck height and -7.2cc dome displacement we will be at approx 9.26:1 CR
Old Dec 24, 2003 | 02:14 PM
earl's Avatar
We can only really guess on the piston to deck height. Who knows if the block has been decked. The C5 CP Pistons come with a zero deck height as standard. On these kind of deals, you really don't know what to expect until you throw a piston in.
Old Dec 24, 2003 | 02:17 PM
earl's Avatar
That little measurement can really make a change
Old Dec 24, 2003 | 02:40 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">We can only really guess on the piston to deck height. Who knows if the block has been decked. The C5 CP Pistons come with a zero deck height as standard. On these kind of deals, you really don't know what to expect until you throw a piston in. </TD></TR></TABLE>
True only TRUE way to do it is cc the head and then the piston in the block.
Old Dec 24, 2003 | 05:58 PM
thanks guys!
btw, ten thou was taken off the block.
hYbRid_Eg6
Dec 20, 2009 07:01 PM
ls_bitik
Aug 9, 2007 08:22 AM
WorrGame13
Mar 30, 2007 03:35 PM
OEMcivic
Jan 5, 2005 08:20 AM
Hoodwinked
Jan 19, 2004 08:34 PM
