remove the resitor box or not that is the question.
Old Dec 24, 2003 | 11:45 PM
curt801's Avatar
Default remove the resitor box or not that is the question.
i am going to be putting a b17 into my 88 crx si. to do the swap i was going to keep the obd1 injectors and remove the resistor box. But i am only going to be na for a few months and i want to put in some dsm ijectors. which require a resistor box so i have read. so what should i do? i guess i could always remove the box for a while and when i am finally ready for boost i could put it back in. would this work? another question i have is when i run a resistor box do i have to run an obd 0 ecu? i just don't want to mess up and have to do everthing twice.
Old Dec 25, 2003 | 10:04 AM
Del_Slowest's Avatar
Default Re: remove the resitor box or not that is the question. (b1788crx)
just use the obd0 injectors in the b17 and keep the resistor box.
Old Dec 25, 2003 | 10:55 AM
curt801's Avatar
do i have to use an obd 0 ecu with obd0 injectors?
Old Dec 25, 2003 | 11:05 AM
TeStUdO's Avatar
Default Re: (b1788crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b1788crx &raquo;</TD></TR><TR><TD CLASS="quote">do i have to use an obd 0 ecu with obd0 injectors?</TD></TR></TABLE>
I would assume so
Old Dec 25, 2003 | 12:44 PM
curt801's Avatar
anyone know for sure? what if i put the dsm injectors in they require a resistor box but people use them on obd1 cars all the time. right? so i would think that they still use obd1 ecu's.
Old Dec 25, 2003 | 08:22 PM
yes u have to use obd0 ecu, otherwise if you will fry ur ecu
Old Dec 25, 2003 | 08:55 PM
Sonny's Avatar
You can use the OBD1 ECU in an OBD0 car and not worry about the injectors being OBD0 or DSM. As long as the resistor pack is left in place, you're ok.
The other problem that you'll have is that the OBD1 ECU will require and OBD1 or OBD2 distributor (24 tooth trigger). The OBD1 ECU will not work with an OBD0 distributor (16 tooth trigger).
Sonny
Old Dec 25, 2003 | 11:20 PM
curt801's Avatar
thanks sonny that was exactly what i needed to know. i have obd1 parts so it won't be a problem.
Modified by b1788crx at 1:34 AM 12/26/2003
Old Dec 26, 2003 | 07:55 AM
i always only give part of the info ppl need. i guess i need to start typing more
RACEPAK
Engine Management and Tuning
Apr 6, 2010 04:14 PM
schock3
Aug 25, 2009 12:37 PM
SFlCrx
Mar 21, 2007 05:48 PM
crawlin
Aug 17, 2006 06:52 PM
7rrivera7
Jan 17, 2005 02:07 PM
