Trying to diagnose my turbo civic's overheating issue...
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Here's some background info. on the car:
- 1997 civic EX coupe, 114k
- Bought with 73k in April 2001
- Not-a-one problem until now
- Oil changed regularly
- Haven't touched the coolant since I got the car
- Timing belt replaced, water pump "said" to be fine by mechanic (not sure though)
Here are some symptoms I've documented:
- The car is taking longer and longer to warm up; first the temp. gauge gets to normal operating temp. , then the heater kicks in about 1-2 minutes later. VERY annoying in 10 degree Minnesota winter weather.
- After about 10 minutes of driving, the temp. gauge starts to creep up from 1/3, where it has been since I've owned it for the last 2.5 yrs., to about 1/2 way then all the way up to just below the H in some cases, before it drops abruptly down to about 1/2 way. Then it'll do it all over again after about 5 min. at normal operating temp.
- The temp. level goes back to about 1/2 or even 1/3 when I put the heater on full blast for about 30 seconds or so. Then the ******* thing just does it again after about 5-10 min.
- I have checked my oil, it is not milky at all. No signs of coolant in my oil, or oil in my coolant (i.e. overflow tank).
- When it first started to overheat, I pulled over and popped my hood. The coolant was JUST above the MAX level, and yet the temp. was consistently at roughly 3/4 level.
- Now, after about a week or two, when it happened again (didn't happen in between that time), I noticed the coolant level in the overflow tank was below the min., however there was no sign of any coolant in my engine bay or on any parts that I could see. But I'm not really sure what it would look like all over the engine bay, green I assume? If so, then I didn't see any.
- My plugs look normal.
- When the overheating issue occurred and I had a chance to pop my hood (usually I'm in a rush to get to my class so I can't always check it), I check the upper hose, which is immediately hot to the touch, whereas the lower hose is relatively cold. Not freezing, I can feel the warmth, but nowhere near the upper hose.
- I haven't noticed any leaks in my driveway, but then again, I haven't really been under my car since the snow fell about a month ago.
- There are no signs of white smoke coming from my exhaust, either at idle or WOT when boosting.
- I have NOT opened the radiator cap, because I constantly forget to before I drive the car, so it's too hot to touch then . Is there a certain level that I'm supposed to gauge it by on the radiator?
- My fan goes on only sometimes, when it overheats it's only on about 30% of the time, meaning sometimes it's on when it overheats, and sometimes it isn't. This points to a faulty thermostat.
Here are the possible causes I'm guessing may be the culprit:
- faulty thermostat
- old coolant (time for flush/refill)
- faulty radiator cap
- faulty water pump
- leaky headgasket
- air bubble in coolant system
Being a cheap bastard like I am, I hope that the issues are contained in the smiley brackets. If it's a water pump - oh well, I've budgeted for it to go bad. If it's the headgasket, well...I can't afford labor, so I'll be bustin' out the Haynes and gettin' to work!
Ideas?
- faulty thermostat
- faulty water pump
- leaky headgasket
Ideas?
O.G. triple O.G.
Re: Trying to diagnose my turbo civic's overheating issue... (boostincoupe)
Replace your temperature sending unit....they do go bad more often than most peple think.....cost = around $13.00 and you don't necessarily need to buy OEM either.....
Re: Trying to diagnose my turbo civic's overheating issue... (NVturbo)
what you describe sounds like classic symptoms of a bad thermostat, especially this one:
"When the overheating issue occurred and I had a chance to pop my hood (usually I'm in a rush to get to my class so I can't always check it), I check the upper hose, which is immediately hot to the touch, whereas the lower hose is relatively cold. Not freezing, I can feel the warmth, but nowhere near the upper hose."
Re: Trying to diagnose my turbo civic's overheating issue... (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared »</TD></TR><TR><TD CLASS="quote">what you describe sounds like classic symptoms of a bad thermostat.</TD></TR></TABLE>
Beautiful. I'll be fixing it tomorrow. But do you guys think my water pump is okay, being 114k old?
I had the problem of overheating, and the temp gauge would go up and down also.....I was low on coolant and the radiator had a hole in it.
If you are taking coolant out of the overflow I bet you have a leak somewhere.
If you can pop off the radiator cap.
When I had the problem I was on a kinda long trip, so I just threw water in the radiator so I could make it the rest of the way home.
Once the water was in there the heater worked fine, and the temp no longer fluctuated.
Re: Trying to diagnose my turbo civic's overheating issue... (HXMan)
Join the club, I have the same symptoms as you in my 92 dx hatch. The only difference is my fan doesnt work. I replaced the thermostat today, and it still over heats. Try the thermostat first.
Well I solved it...it was my radiator cap.
Re: Trying to diagnose my turbo civic's overheating issue... (Night_Minx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Night_Minx »</TD></TR><TR><TD CLASS="quote">compression test will rule out/confirm the headgasket.
not always. When the temp gauge is hot, does your heat work at all?
Re: Trying to diagnose my turbo civic's overheating issue... (racinskittle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle »</TD></TR><TR><TD CLASS="quote">
not always. When the temp gauge is hot, does your heat work at all?</TD></TR></TABLE>
My car's not overheating anymore...
...and it's back from the ******* dead because she's overheating again.
- temp. rises at idle and fluctuates slightly while driving
- overflow fills up (I don't think it's overflowed though, or I'm blind)
- car bogs from time to time, stutters kinda (runs shittier basically)
- however, no white smoke, oil in coolant, coolant in oil
ARP headstuds and OEM headgasket coming soon.
smeltjr
09-17-2010 05:28 PM
boostincoupe
12-30-2003 06:46 PM
boostincoupe
12-26-2003 08:00 PM
