Problem with isolation valve and map sensor...
Old Dec 24, 2003 | 02:44 PM
eghatchproject's Avatar
Default Problem with isolation valve and map sensor...
Hey guys I just recently installed a turbo kit on my 2001 civic and I am having issues with the map sensor. I am using an isolation valve in between the hole that leads into the intake manifold and the map sensor and I still have a CEL and idling problems. Sometimes it will idle fine but then when I hit the gas it idles up and down repeatedly. Sometimes it will just idle really high like 2000 rpms. Any ideas what I should do? I ordered the new missing link for the d17/rsx but its not coming in til monday.
Thanks
Old Dec 24, 2003 | 02:50 PM
mattssi's Avatar
how is it that you hooked up your deal? Look at the drag kit install sticky and see how they did that one, It works just fine!
Old Dec 24, 2003 | 02:54 PM
where is this sticky?
hole leading to IM ---> isolation/check valve ---> map sensor
all on top on each other
Old Dec 24, 2003 | 03:33 PM
my check valve has a very little hole in the side of it but it looks like one of those fishing thingy's lol
Old Dec 24, 2003 | 03:45 PM
mattssi's Avatar
Default Re: (eghatchproject)
It looks like this
Old Dec 24, 2003 | 05:16 PM
Default Re: (mattssi)
check out what im using...
of course it is not working as of right now
khkchan
Sep 13, 2012 11:21 AM
shaggyeg6si
May 15, 2008 07:48 AM
teggreen4
May 13, 2005 02:12 PM
