Something really wrong with my TURBO!!!! HELP!!!!!
Old Dec 26, 2003 | 08:34 AM
k2civic's Avatar
Default Something really wrong with my TURBO!!!! HELP!!!!!
I just got my REV Hard Kit Installed in my 2000 Honda Civic. What is happening is my Fuel Gauge in my car is going up and down! I am losing MAD power SEEMS like it's worse then stock. I was wondering what could be wrong?? Is it my Fuel Pressure Regulator?? Or what?? It came with the REV HARD kit. PLEASE HELP!!!!!
Old Dec 26, 2003 | 08:41 AM
GRTechnologies's Avatar
Default Re: Something really wrong with my TURBO!!!! HELP!!!!! (k2civic)
try your fuel pump it might be going bad
PrecisionH23a's Avatar
Did you run your FMU lines backwards? Did you install an inline or intank? Is the gauge going up and down at idle or under load? Did you check for leaks?
Old Dec 26, 2003 | 08:42 AM
b18bturbo's Avatar
first off did you hook the inline fuel pump correctly. Second i would check your wiring to the main relay that you used fro your fuel pump. Also there is so many different things it could be. I would try to check codes comign from ECU if any. Map sensor is usually one of the culprits
Old Dec 26, 2003 | 08:43 AM
k2civic's Avatar
No it was running really good. Just today it is acting funny. I don't know how to check for leaks. Please help. When idleing it goes down when i am driving it goes back up. The fuel guage that is. I don't think i install it backwards cuz it was running fine untill today. ANY AVICE IS GREATLY APPRECIATED.!!
Old Dec 26, 2003 | 08:45 AM
b18bturbo's Avatar
is it the guage just fluctuatiing or is it causing the car to hesitate etc.
Old Dec 26, 2003 | 08:48 AM
k2civic's Avatar
Default Re: Something really wrong with my TURBO!!!! HELP!!!!! (b18bturbo)
It is flucuating but not cuase by the car hesitating. The car hesitates a lot when i try to rev or give it gas it takes like two to three sec before the car responds and it responds like stock response NO POWER! I use to can feel mad power now its worse then stock. Please HELP!!!
THANKS FOR ALL THE REPLY's SO FAR!
Old Dec 26, 2003 | 11:31 AM
Boltz's Avatar
my best quess is that it is your fuel pump acting up because you have a low amount of gas 1/4tank or less..... your fuel pressure will fluctuate when you have low level of gas and a nice hi flow aftermarket pump,....
hope this is your problem, because everyone *hopefully* knows how to gas up
Old Dec 26, 2003 | 11:33 AM
Slammd Sol's Avatar
mine did that when i had a bad ground
Old Dec 26, 2003 | 11:57 AM
c jackson's Avatar
threes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k2civic &raquo;</TD></TR><TR><TD CLASS="quote">I don't know how to check for leaks. </TD></TR></TABLE>
heh
Old Dec 26, 2003 | 12:27 PM
Happyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k2civic &raquo;</TD></TR><TR><TD CLASS="quote">It is flucuating but not cuase by the car hesitating. The car hesitates a lot when i try to rev or give it gas it takes like two to three sec before the car responds and it responds like stock response NO POWER! I use to can feel mad power now its worse then stock. Please HELP!!!
THANKS FOR ALL THE REPLY's SO FAR! </TD></TR></TABLE>
Wait, what guage is it? Fuel Pressure Gauge? Or is it an Air Fuel Gauge? cause if it's the air fuel gauge its gonna fluctuate up and down unless you're at WOT.
Old Dec 26, 2003 | 06:49 PM
Boltz's Avatar
Default Re: Something really wrong with my TURBO!!!! HELP!!!!! (Happyman)
now that ive read it twice it seems that it is his fuel gauge, as in volume, not pressure
Old Dec 26, 2003 | 07:42 PM
leadfoot78's Avatar
Default Re: Something really wrong with my TURBO!!!! HELP!!!!! (Boltz)
Check the fuel pump. Maybe u installed it wrong, maybe the pick up came off. I have heard of this problem before, u have to be care full when u insert the fuel "pillow" on the end of the pump, it has to go as low into the tank as possible.
DRIVENRacing
May 22, 2004 10:41 PM
Boostless97Lude
Dec 26, 2002 11:33 AM
rbf351
Nov 27, 2002 04:46 AM
mockujin
17
Nov 24, 2002 05:11 PM
zerodrag29
Mar 1, 2002 09:51 PM
