Need help tapping manifold for EGT
Old Dec 25, 2003 | 09:52 AM
Rain_man's Avatar
New User
Default Need help tapping manifold for EGT
I'm trying to tap my inline pro manifold for an EGT and I've drilled a hole w/ a 5/16 bit. However, I can't get the 1/8 NPT tap I'm using to catch and start making threads. I'm using a tap wrench to do this.
Anybody have any tips or insight as to what I might be doing wrong?
Thanks,
Keith
Old Dec 26, 2003 | 06:06 PM
bluebullet's Avatar
Default Re: Need help tapping manifold for EGT (Rain_man)
I believe the correct bit is a size "R" drill bit. They are hard to find, but an 11/32 can also be used.
Old Dec 26, 2003 | 06:50 PM
IN VTEC's Avatar
Another option is to use a weld-on 1/8" female adapter (ATM-2260 is the only one I know of thus far).
Dr Pooface's Avatar
Default Re: Need help tapping manifold for EGT (bluebullet)
What kind of tap are you using? A taper style tap has a lead of about 8 threads, this helps with "bite".
Old Dec 26, 2003 | 06:53 PM
bluebullet's Avatar
Default Re: Need help tapping manifold for EGT (Dr Pooface)
I think the 5/16 bit is just a hair too small, thus making it difficult to start the tap
Old Dec 26, 2003 | 07:00 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluebullet &raquo;</TD></TR><TR><TD CLASS="quote">I think the 5/16 bit is just a hair too small, thus making it difficult to start the tap</TD></TR></TABLE>
yup
Old Dec 26, 2003 | 07:10 PM
Flamenco-T's Avatar
Default Re: Need help tapping manifold for EGT (Jared)
get 11/32 bit and use plenty of lubricant when you tap it
stan
Old Dec 26, 2003 | 07:34 PM
V-SPEC 1's Avatar
Default Re: Need help tapping manifold for EGT (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">get 11/32 bit and use plenty of lubricant when you tap it
stan</TD></TR></TABLE>
Yeah, I'll be using 11/32 bit when I'm ready to drill my full-race mani. with Defi BF gauge.
Old Dec 30, 2003 | 10:20 PM
Rain_man's Avatar
New User
Default Re: Need help tapping manifold for EGT (boostedb20vtec)
Thanks guys for all the help. You guys were right, the bit was a little too small.
Agtronic
Welding / Fabrication
102
Mar 3, 2009 03:23 PM
krytykalintentions
May 24, 2007 07:08 PM
Keyhole
12
Aug 31, 2005 05:15 AM
JMcDB18C
Apr 20, 2005 03:25 AM
buck02
Apr 2, 2004 12:21 PM
