The Audi
Old Dec 24, 2003 | 01:27 PM
Justin Olson's Avatar
Default The Audi
Merry Christmas
Modified by Justin Olson at 6:27 PM 3/19/2004
Old Dec 24, 2003 | 01:28 PM
boosted jetta's Avatar
Default Re: The Audi (olsonjus)
you sure you should be using PVC for the manifold?
Old Dec 24, 2003 | 01:38 PM
Default Re: The Audi (boosted jetta)
Weld els are on there way.
Old Dec 24, 2003 | 01:51 PM
RedStarGsr's Avatar
looks nice justin! great thinkin w/ the pvc outline...creative. and of course codys work is top notch
keep us posted... how much boost are you lookin at for 550+?
Old Dec 24, 2003 | 01:56 PM
Default Re: The Audi (RedStarGsr)
Well, I'm looking at running meth injection on top of pump fuel so I'm really not sure how much power its going to make. I plan on running upto 26psi on pump w/ meth injection. That should get me at least 550 crank. Then I'll build the motor and try to max out this turbo. Its good for 65lbs of air so it should get interesting.
Justin
Old Dec 24, 2003 | 02:07 PM
Disco Stu's Avatar
I love seeing this ****! Way to be original!
Old Dec 24, 2003 | 02:32 PM
hpfsi's Avatar
That is awesome! Congrats on the great work - I love to see people putting ideas together from scratch. Do you ever come up to Portland?
Old Dec 24, 2003 | 03:12 PM
Derek14's Avatar
Default Re: The Audi (hpfsi)
who needs metals for manifolds... just go to Home Depot and make one from pvc...
Old Dec 24, 2003 | 03:24 PM
DA-MAX's Avatar
Default Re: The Audi (Derek14)
I heard PVC helps the turbo spool faster what model Audi is it??
Old Dec 24, 2003 | 04:57 PM
Tinker219's Avatar
Default Re: The Audi (DA-MAX)
thats sweet! Good luck welding up the PVC
I was wondering what you were going to do for the runners, it looks awesome!
Old Dec 24, 2003 | 07:37 PM
rtype11's Avatar
we got a guy here in toronto with a very similar set up, he has full heim joint suspension though and a lot more cutom items, he also sapped in the quatro awd. he still cant find a clutch that can hold without breaking / axle.
Old Dec 24, 2003 | 07:51 PM
project dc2's Avatar
Default Re: The Audi (Tinker219)
hahahah myf riend use the same materials to try to mimic some manifold desgins ..f unny ****
Old Dec 24, 2003 | 08:38 PM
m R g S r's Avatar
Default Re: The Audi (project dc2)
Was that motor originally turbo?
Old Dec 24, 2003 | 10:26 PM
Accord94DX's Avatar
Default Re: The Audi (m R g S r)
034efi management?
Old Dec 25, 2003 | 01:40 AM
swissturbo's Avatar
yes that engine is boosted stock already,i think its a audi s2.
Old Dec 25, 2003 | 06:36 AM
vti2's Avatar
Hi iff you need some help to tune your engine let me know, i buildet some audis with 2,2 20v turbo engine, the stongest one ist allmost ready it should have 700hp at the cranck, the oder two that i build hasr 50hp at the crank.
I saw at the pictures you have a 3b engine, to make 500hp you will need a ABY engine, it is stronger, is the same engine that comes on the audi RS2, put a KKK29 on it, porshe twinturbo injectors, a 3 bar KPR, a 5 bar fuel pressure regulator, polish your rods or they will bracke, and pic up a 6 gear tranny the 5 gear tranny will only hold 350hp., you will also need another rod bolts, you should pic it from MTM they are the bes ones for audi.
Old Dec 25, 2003 | 06:38 AM
vti2's Avatar
Your engine isn not the same has Dahlbäks one the have the ABY from RS2 audi you have the 3B that is a older version.
Old Dec 25, 2003 | 07:49 PM
Default Re: The Audi (vti2)
This car is a 91 audi 200 turbo quattro. They come with 217 hp stock out of a 2.2 liter 5 cylinder. If you want to read about it check out this link:
http://www.s-cars.org/200/overview/overview.html
My engine is VERY simliar to the dalhback engine. I'm just trying to relate it so the honda-tech guys have an idea of the potential of this motor. I have no worrys that my motor will hold up to well over 650hp when its is finished. I'm going to build the motor with pauter rods and JE pistons. ARP rods, mains, head studs. With that basic setup the motor shouldn't have any problems standing upto 35psi. For the tranny I'm going with a 6spd out of the newer twin turbo S4.
When I build the bottom I'm going to run 9:1 CR. I'm going to run 7a cams out of the naturally aspired 20v. This is no honda, but should make power too 8500 rpm. The turbo I'm going to run should come on very similar to a sc61 so I'm expecting full boost on this 2.22L at 4000-4500 rpm. I'm going to run 20psi on straight 92 octane and 25+psi on pump/meth.
I'm not trying to make the fastest car in the world, just something that an allaround fun car to drive. Its really too big at 3350 lbs to be anything except a boat. Its does have quattro all wheel drive which is fun for the mountain.
I'm either going to run 034efi or autronic sm2. Trying to figure out which on I like better. 034efi is coming out with some cool technology that is able to monitor the spark plug, then derive cylinder pressure. Should be a really trick way to tune the ignition maps for everything they got
http://www.034efi.com
Justin
Old Dec 26, 2003 | 04:45 AM
vti2's Avatar
here is something from our cars.
http://www.quattrospeed.de/
http://www.msc-dortmund.de/
Old Dec 26, 2003 | 05:14 AM
wolfsburg2's Avatar
the dahlback car has never made 900hp it's an internet myth based on the fact they say on their site the car will make 900hp with a different turbo and other changes. i believe the highest dynop they have is in the 600s.
not trying to be a dick but the dahlback thing kills me, it's spoken so often as truth...
check their site i am not lying it never has made 900hp.
Old Dec 26, 2003 | 06:04 AM
MiraiZ's Avatar
Default Re: The Audi (wolfsburg2)
loving it My first car was an Audi 5000T
Old Dec 26, 2003 | 06:16 AM
swissturbo's Avatar
thats right.the dahlback made max. 720 bhp.
check it out here http://www.dahlbackracing.se/e....html
Old Dec 26, 2003 | 06:22 AM
wolfsburg2's Avatar
Default Re: The Audi (swissturbo)
thanks. everyone always quotes the 900hp thingn and its just accepted. i feel it is my duty to shed light
Old Dec 26, 2003 | 10:41 AM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swissturbo &raquo;</TD></TR><TR><TD CLASS="quote">thats right.the dahlback made max. 720 bhp.
check it out here http://www.dahlbackracing.se/e....html </TD></TR></TABLE>
Man that is a sweet looking VW
Old Dec 26, 2003 | 11:25 AM
89dxhunchback's Avatar
Default Re: The Audi (TeStUdO)
No doubt, that bitch is BAD !!! Even if it didn't have an insane amount of HP, its still bad ***.
What kinda times is that car running ??
