Does this Filter solution look like itll work??
Old Dec 23, 2003 | 11:56 AM
-iLLuZioN-B18C1's Avatar
Default Does this Filter solution look like itll work??
I picked up a flexible aluminum duct piping that is 3" in diameter from home depot.
do you think this will work? will it get too hot?
oh, dont mind the panty hose, im not driving this thing around right now, im just putting it there so nothing gets in it.
forgot to ask, when i get a filter, does it matter if i get one that will clamp INSIDE the aluminum duct or one that will clamp AROUND/OUTSIDE the duct.
Old Dec 23, 2003 | 12:11 PM
blackdc's Avatar
Default Re: Does this Filter solution look like itll work?? (-iLLuZioN-B18C1)
Well if you clamped it on the inside, the filter would have to have a hard surface inlet, rather than a rubber one, or else its not going to tighten.
Old Dec 23, 2003 | 12:25 PM
Tad's Avatar
Tad
is the tubing exactly 3"
i have an "almost 3" " short ram,
and a kn cone filter, and I just shoved the kn filter inside the shortram, no fastener or anything, the kn has a rubber end, so it just shoved in and is nice'n tight!!
Old Dec 23, 2003 | 01:31 PM
Jared's Avatar
Default Re: (Tad)
you could use a short piece of 3" pipe(around 1-2"), clamp the filter on one side, shove the hose on the other end up to the end of the filter and clamp it down.
Old Dec 23, 2003 | 05:53 PM
Default Re: (Tad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tad &raquo;</TD></TR><TR><TD CLASS="quote">is the tubing exactly 3"
and a kn cone filter, and I just shoved the kn filter inside the shortram, no fastener or anything, the kn has a rubber end, so it just shoved in and is nice'n tight!! </TD></TR></TABLE>
it is exactly 3"
exactly what was the diameter of your filter?
LuckyStrike90
May 23, 2018 11:06 AM
VtecDA9
Dec 1, 2005 07:17 PM
DJtal Chaos
Audio / Security / Video
Apr 8, 2004 02:33 PM
TheHater
12
Jun 8, 2002 06:27 AM
travis
May 2, 2002 01:23 PM
