problems with avcr......
Old Dec 23, 2003 | 05:45 PM
ATS*Mark's Avatar
OG triple OG
Default problems with avcr......
ok i still cant get this thing to control boost..... when i monitor the "SOL" function im asuming thats the solenoid right??? its opening to around 20% at .60 bar i believe....why cant i get this thing to control boost, the solenoid isnt bad is it????? i dont get it...
Old Dec 23, 2003 | 06:18 PM
SpeedDreamz.com's Avatar
Default Re: problems with avcr...... (Hella_JDM)
Please make sure you have a strong vacuum source. What do you have your duty set at? PSI spring in the wg?
Old Dec 23, 2003 | 06:20 PM
ATS*Mark's Avatar
OG triple OG
Default Re: problems with avcr...... (30psiCiv)
the pressure sensor is T'd into the FPR as per the instructions and the WG is internal which is at 5.5 lbs.....the solenoid is hooked up as per the instructions , COM is connected to the actuator valve , and NO is connected to the compressor
Old Dec 23, 2003 | 07:55 PM
ATS*Mark's Avatar
OG triple OG
bump
Old Dec 23, 2003 | 10:40 PM
ATS*Mark's Avatar
OG triple OG
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">bump</TD></TR></TABLE>
marcussmith26
May 15, 2006 08:21 AM
EKB18BPR3
Jul 3, 2004 09:19 PM
ATS*Mark
Dec 19, 2003 11:42 PM
Duck Sauce
Aug 10, 2002 08:00 PM
