new motor for turbo??
Old Dec 26, 2003 | 09:48 PM
Turbo-Honda's Avatar
Default new motor for turbo??
Quick option needed help.
Fix the motor Or Change to new motor .
I have a 95,000 mile b18 motor vs 30,000 same new motor. (for Turbo)
$800 fix or $1500 new motor
Would this motor perform exactly the same what ever I pick??? I'm running it on turbo and 7psi of boost max.. Gasket blew on current motor, cost of fix little bit off that why asking for opinion...Would it worth it???
Thanks for any reply guys..
Old Dec 26, 2003 | 09:57 PM
bigwig's Avatar
why do you need to fix it? why cant you just boost 7psi on the motor you have?
I'm gonna boost 11-12psi on my B18b1 w/ 114,xxx miles on it
Old Dec 26, 2003 | 10:03 PM
Default Re: (bigwig)
Would it be ok for you to boost that high???
I boost at 8psi and blow up my gasket and smoke and coolant all over... If i'm going to change the gasket you think I would be ok without blow it up again???
Thank for replies..
Old Dec 26, 2003 | 10:58 PM
bigwig's Avatar
i wouldnt do it if it werent practical. fuel management and tuning is important in any turbo setup though.
Old Dec 26, 2003 | 11:10 PM
1700anddroping's Avatar
when you seperate the head like your talking about,make sure the surface of your head is flat,and invest in some arp head studs.you should not be blowing head gaskets @ 8 psi.
now back to our regular program.
400hpJDMSI
11
Aug 3, 2005 06:37 PM
C_H_A_D
Jan 31, 2005 03:41 PM
s2kkid
Sep 11, 2004 07:36 AM
Turbo-Honda
Feb 27, 2004 08:07 PM
