Throwing around this idea for next setup, critiques please
Old Dec 22, 2003 | 05:21 PM
Pfieff's Avatar
Default Throwing around this idea for next setup, critiques please
Current setup is the greddy 15g kit on my d16y7 @10psi. I was throwing this around for an idea for things to do for next month:
cp pistons(already bought, just waiting to put in)
manley rods(already bought, just waiting to put in)
maxrev mani
t3/t04e 50 trim .48 a/r
tial WG
upgrade the rc 440's to some 550's
Goal would be ~300whp @~20psi but with a nice amount of torque. Tuning is done with hondata s100b. Thanks,
Pfieff
Old Dec 22, 2003 | 06:11 PM
fulldragcrx's Avatar
Anything is possible. but, Headwork, cam, ignition. are you planing on these also?
Old Dec 22, 2003 | 09:30 PM
Pfieff's Avatar
Default Re: (fulldragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx &raquo;</TD></TR><TR><TD CLASS="quote">Anything is possible. but, Headwork, cam, ignition. are you planing on these also?</TD></TR></TABLE>
Not from the get go. Should I be able to hit 300whp without any head work?
Old Dec 22, 2003 | 09:40 PM
TurboJesse
Guest
Posts: n/a
Default Re: (Pfieffdog)
i would do a z6 or y8 head while your at it, there cheap as hell, you'l make more power and can rev higher.
Old Dec 22, 2003 | 10:20 PM
BauleyCivic's Avatar
Risky Business
Default Re: (Mpir3)
I'd get a clutch upgrade too if I were you...something that will be able to handle 20 psi. Also you dont think you need to sleeve your block?
Old Dec 22, 2003 | 11:44 PM
FredoSP's Avatar
Default Re: Throwing around this idea for next setup, critiques please (Pfieffdog)
stock axles? and im assuming a 3" exhaust?
Old Dec 23, 2003 | 03:31 AM
Pfieff's Avatar
Default Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic &raquo;</TD></TR><TR><TD CLASS="quote">I'd get a clutch upgrade too if I were you...something that will be able to handle 20 psi. Also you dont think you need to sleeve your block?</TD></TR></TABLE>
Right now I am running a SPEC stage 3 clutch so I think that will be suffiecient for now. I shouldn't have to sleeve as D series sleeves are good to ~400whp with proper tuning, right?
Old Dec 23, 2003 | 03:32 AM
Pfieff's Avatar
Default Re: Throwing around this idea for next setup, critiques please (FredoSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FredoSP &raquo;</TD></TR><TR><TD CLASS="quote">stock axles? and im assuming a 3" exhaust?</TD></TR></TABLE>
Axles are stock, I'm running a quaife now and have polyurethane motor mounts. Debating on the jimfab traction bars.
Old Dec 23, 2003 | 11:07 AM
bluesiTYPER's Avatar
I'm with fulldragracecrx on the ignition upgrade ..
Old Dec 23, 2003 | 11:30 AM
Pfieff's Avatar
Default Re: (DC5 Extreme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5 Extreme &raquo;</TD></TR><TR><TD CLASS="quote">I'm with fulldragracecrx on the ignition upgrade ..</TD></TR></TABLE>
I thought that stock honda ignitions were ok up to like ~450whp, someone correct me if i'm wrong.
Old Dec 23, 2003 | 12:08 PM
TurboJesse
Guest
Posts: n/a
you don't need to upgrade the ignition for 300-350whp.
Old Dec 23, 2003 | 05:07 PM
Pfieff's Avatar
ttt
Old Dec 23, 2003 | 05:26 PM
MikeMAN's Avatar
stock sleeves are the least of your worries, same as ignition..
seem to have a good list!! I would get 550's for some breathing room.
good luck! that should be easily attainable!
mike
BigMoneyP
Sep 12, 2005 07:28 AM
chippy
Dec 2, 2004 02:20 PM
Pfieff
Jul 15, 2004 06:06 PM
EK_vzla
Feb 7, 2004 09:00 AM
