What is wrong with this oil return line?
Old Dec 25, 2003 | 07:16 PM
Rod.'s Avatar
Default What is wrong with this oil return line?
Some reason now oil is coming out by the oil return line from the turbo part. It never did it when I put the kit on. I had a wreck with it ,but I doubt it ruined the seals. Hope the picture will help. Tell me your opinion please!!
Modified by redturbocivic at 4:26 AM 12/26/2003
Modified by redturbocivic at 4:27 AM 12/26/2003
Modified by redturbocivic at 4:29 AM 12/26/2003
Old Dec 25, 2003 | 07:35 PM
JM Performance's Avatar
Default Re: What is wrong with this oil return line? (redturbocivic)
make sure that the oil bung (the part that goes in the pan) is the lowest part. dont let it sag then come back up. Also, maybe get a gasket in there?
Old Dec 25, 2003 | 07:44 PM
Rod.'s Avatar
Default Re: What is wrong with this oil return line? (00SilverLS)
Would it make that oil spew back out of there? I had a shop take my downpipe off to weld a bung into it and they never told me about any oil in there. So I do not think it is the seals giving away.
Old Dec 25, 2003 | 07:47 PM
t04ecvc's Avatar
I don't think he is talking about internal gaskets, just a gasket on the part where the line blots to the turbo.
Old Dec 25, 2003 | 07:55 PM
Rod.'s Avatar
Default Re: What is wrong with this oil return line? (jz)
between where those two bolts are and the turbo. No I do not have gasket that i know of. I bought this kit used. It was not abused though. It was fine in my civic. Now I put it on my teg this starts. Think I just need to put a gasket up there or a new one?
Old Dec 25, 2003 | 09:13 PM
yeah, get a gasket or use some liquid gasket (something that wont burn right off)
Old Dec 25, 2003 | 09:24 PM
turbod16y8's Avatar
liquid gasket will work fine.
Old Dec 26, 2003 | 05:19 AM
SpoolnG2's Avatar
Default Re: What is wrong with this oil return line? (turbod16y8)
to me, that oil return line looks kinda small. I use a -10 line on mine. maybe the oil is backing up for some reason. just a thought.
Old Dec 26, 2003 | 06:10 AM
JonnyCoupe's Avatar
Default Re: What is wrong with this oil return line? (SpoolnG2)
you need a gasket, simple fix
Old Dec 26, 2003 | 06:17 AM
Rod.'s Avatar
It is a -8 return line. My friend reccomended me to get it. I going to try to get that liquid gasket stuff. Hope that solves my problem. I wonder is that causing my white smoke to come out the exhaust? I will get on it ,then left off white smoke or bluish whitesh smoke comes out my exhaust. Is it this or piston rings?
Old Dec 26, 2003 | 06:25 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: What is wrong with this oil return line? (JonnyCoupe)
Just use some rtv buddy, mine did the same, it was a quick fix.
Old Dec 26, 2003 | 06:55 AM
D16A6Turbo's Avatar
Default Re: What is wrong with this oil return line? (SIXTYdashONE)
when you guys talk of liquid gasket, is it that high temp silicone stuff. Is that what the rtv stuff is?
Old Dec 26, 2003 | 07:02 AM
Rod.'s Avatar
Default Re: What is wrong with this oil return line? (D16A6Turbo)
i am wondering also
Old Dec 26, 2003 | 08:43 AM
RenoRacing's Avatar
RTV is just a high temperature liquid silicone gasket maker. You'll see them at any auto parts stores or even walmarts. they are in a tooth paste like tube, one will say "RTV" it's orangish copper I believe.
Old Dec 28, 2003 | 03:45 AM
iam7head's Avatar
neither gasket are fine, my high temp. gasket in a tube never failed me.
it just the picture or the return line looks really small?
mine was meaty and well wrapped in high temp. foil thing
Old Dec 28, 2003 | 05:32 AM
incogNitto's Avatar
http://www.atpturbo.com/Mercha...e=OIL
$1.65 to make your troubles go away.
Old Dec 28, 2003 | 07:14 AM
D16A6Turbo's Avatar
Default Re: What is wrong with this oil return line? (incogNitto)
cool...never knew they made those...thanks
Old Dec 28, 2003 | 07:26 AM
Rod.'s Avatar
thanks
hondaeg8
May 22, 2006 03:12 PM
mamaboy
Jan 25, 2004 10:38 PM
wrXtian
Apr 11, 2003 12:00 AM
shamoo
Oct 29, 2002 11:08 AM
GruvyTune
Nov 18, 2001 03:59 PM
