High Boost B16...how important are head studs?
Old Dec 25, 2003 | 05:27 AM
VanHonda's Avatar
Default High Boost B16...how important are head studs?
I am rebuilding my B16 with sleeves and forged internals for high boost. How important is it to use head studs, or can I just run new factory head bolts, since I just bought them about a month ago for my last build.
Also, I see from searching that an oem head gasket is one of the best...if tuned properly will it be able to hold 20+ psi, or should I go with a Cometic HP?
Thanks and Merry Christmas,
Craig
Old Dec 25, 2003 | 07:44 AM
ladysman's Avatar
Default Re: High Boost B16...how important are head studs? (VanHonda)
Only use headstuds.
Headstuds seal the gasket much better as they can spread the pressure across the area better. Best freaking $100 you will spend on that motor. Period.
Old Dec 25, 2003 | 09:30 AM
SpoolnG2's Avatar
Default Re: High Boost B16...how important are head studs? (ladysman)
ARP or AEBS
i personally use ARP. they been around for a while and are proven allready.
Old Dec 25, 2003 | 09:33 AM
b18bturbo's Avatar
Default Re: High Boost B16...how important are head studs? (SpoolnG2)
yup headstuds are worth every penny its what keeps the head from lifting at high levels of boost.
ARP or AEBS both high quality studs. If you want th best get you head machined fro some arp 1/2 head studs for the ultimate hold
85mmek9
Apr 19, 2010 08:25 AM
ej1252
Nov 12, 2007 03:43 PM
D-meet07
Nov 4, 2004 06:29 PM
blu2ksi
Dec 13, 2003 01:27 PM
Ri5e
Sep 9, 2002 01:13 PM
