hooking up s300 launch control switch
Old Mar 11, 2007 | 07:31 PM
mike93eh2's Avatar
Default hooking up s300 launch control switch
hey guys i was wondering how i would go about hooking up a switch to activate the launch control in s300. right now i have it set to always on and want to be able to switch it off to heat up the slicks. is there any way i could activate it when the emergency brake is pulled up?
if not a manual switch will be fine also. lets say i wanted to use the air conditioning switch option to activate it. do i just wire a switch to B5 on the ecu or what? dont quite get it.
thanks for the help
Old Mar 11, 2007 | 07:34 PM
A.E Motoring's Avatar
Default Re: hooking up s300 launch control switch (mike93eh2)
u dont need a switch, it works off of mph, once it reaches a certain mph, it diactivates
Old Mar 11, 2007 | 07:39 PM
mike93eh2's Avatar
Default Re: hooking up s300 launch control switch (Dual Cam Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dual Cam Racing &raquo;</TD></TR><TR><TD CLASS="quote">u dont need a switch, it works off of mph, once it reaches a certain mph, it diactivates</TD></TR></TABLE>
well i want one anyways..at least maybe one that works off the ebrake.
Old Mar 11, 2007 | 08:59 PM
mike93eh2's Avatar
anyone?
Old Mar 11, 2007 | 09:00 PM
building boost's Avatar
i think he wants to start his burnout at a different rpm than he launches at. for example, if he launches at 4500 rpm, his launch control will be set at 4500 rpm. when its time to do his burnout he may want to rev it to 7000 rpm and drop the clutch.
Old Mar 11, 2007 | 09:21 PM
mike93eh2's Avatar
Default Re: (building boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by building boost &raquo;</TD></TR><TR><TD CLASS="quote">i think he wants to start his burnout at a different rpm than he launches at. for example, if he launches at 4500 rpm, his launch control will be set at 4500 rpm. when its time to do his burnout he may want to rev it to 7000 rpm and drop the clutch. </TD></TR></TABLE>
something like that...correct..
getting it to activate off the ebrake would be nice since i use that to preload while launching.
Old Mar 12, 2007 | 06:34 AM
mike93eh2's Avatar
bump for assistance
Old Mar 12, 2007 | 06:43 AM
dcturbols's Avatar
If you use your e-brake to preload during launching then you don't want it hooked up to your e-brake.
A lot of people I know hook it up to their a/c switch
Old Mar 12, 2007 | 09:17 AM
Suprdave's Avatar
Default Re: hooking up s300 launch control switch (dcturbols)
If you are on slicks, your launch rpm should prolly be higher than 4500rpm or you will bog. It works really nice off the VSS...the only reason I would hookup a switch would be if you were also using the MSD 2Step and that's nice to have a rpm limiter for your burnout...so you aren't burning out at 8500rpm or whatever. Saves your motor...
Old Apr 30, 2007 | 05:41 PM
mike93eh2's Avatar
Default Re: hooking up s300 launch control switch (Suprdave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave &raquo;</TD></TR><TR><TD CLASS="quote">If you are on slicks, your launch rpm should prolly be higher than 4500rpm or you will bog. It works really nice off the VSS...the only reason I would hookup a switch would be if you were also using the MSD 2Step and that's nice to have a rpm limiter for your burnout...so you aren't burning out at 8500rpm or whatever. Saves your motor...</TD></TR></TABLE>
lets bump this.. ok im going to use the B5 input on the ecu (a/c press. switch)
ok i run a wire from b5 to a switch.. then what do i do with the other wire on the manual switch? ground it?
is the B5 input for the launch control activation option controlled by ground or power switch?
Old Apr 30, 2007 | 06:13 PM
Bjorn20's Avatar
dumb question.... does the s200 also work off of your speed for this same situation?
Old Apr 30, 2007 | 06:56 PM
mike93eh2's Avatar
Default Re: hooking up s300 launch control switch (Bjorn20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bjorn20 &raquo;</TD></TR><TR><TD CLASS="quote">
dumb question.... does the s200 also work off of your speed for this same situation?</TD></TR></TABLE>
dont think it does.
but back to my question..
Old May 1, 2007 | 07:28 AM
92hondalude's Avatar
wire B5 to the power on you cruse control switch and leave the otherwire like it is. thats how i did mine last night.
it you use the cruse control switch you have to use the invert option. hope that helped. let me know if you need anymore help.
Old May 1, 2007 | 12:25 PM
88da3's Avatar
use the clutch switch. thats how mine is setup. so if im moving slower than 2mph then the 6000rpm redline is engaged. anything faster than 2mph and the car is free to to go redline.
Old May 1, 2007 | 01:53 PM
mike93eh2's Avatar
Default Re: (88da3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88da3 &raquo;</TD></TR><TR><TD CLASS="quote">use the clutch switch. thats how mine is setup. so if im moving slower than 2mph then the 6000rpm redline is engaged. anything faster than 2mph and the car is free to to go redline.</TD></TR></TABLE>
i have s300 dont need to use a clutch switch since it can be ran off the VSS.
BUT i want it on a manual rocker switch.
i dont have cruise control. i want it on a rocker switch. how do i wire it? b5 to switch and then switch to what?? ground or power???
Old May 1, 2007 | 04:46 PM
mike93eh2's Avatar
nevermind i got it.
Old May 1, 2007 | 05:12 PM
crxrocks's Avatar
Why don't you describe how you did it for folks who are searching later?
Old May 1, 2007 | 05:18 PM
mike93eh2's Avatar
exactly like i thought..
ran a wire from b5 on the ecu to a rocker switch and then the other wire off the rocker switch to ground.
Bludger
Sep 26, 2010 07:57 AM
DC2*Integra
Audio / Security / Video
Apr 6, 2010 08:28 AM
amb4081
May 12, 2006 10:18 AM
white_98_gsr
May 29, 2005 06:45 PM
