head gasket question?
Old Mar 12, 2007 | 08:30 PM
arielmalespin's Avatar
Default head gasket question?
i have a b16a stock and planning to go turbo maybe 10 pounds of boost anyways u think i should put a thicker head gasket to run safer cuz is gonna be a daily driver, do u think 2 oem headgasket is a good idea? thanks
Old Mar 13, 2007 | 12:54 AM
Dunc's Avatar
BCICAN
Default Re: head gasket question? (arielmalespin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arielmalespin &raquo;</TD></TR><TR><TD CLASS="quote">i have a b16a stock and planning to go turbo maybe 10 pounds of boost anyways u think i should put a thicker head gasket to run safer cuz is gonna be a daily driver, do u think 2 oem headgasket is a good idea? thanks</TD></TR></TABLE>
You should be fine with the stock headgasket. If you blow it up, then just buy ARP head studs and a new gasket and you'll be good to go. Or you can do the ARP's before head if it makes you feel better.
Do not do 2 gaskets though. That's not a good idea.
Old Mar 13, 2007 | 02:32 AM
s2kdre's Avatar
Default Re: head gasket question? (Dunc)
b16 is a low comp motor anyways, u'll be fine with a stock gasket up to 300whp.
Brycen
Jan 1, 2010 02:20 AM
Bc3
Dec 10, 2006 10:41 AM
Jason703Racing
Feb 22, 2006 06:57 PM
trustsohc
Jul 23, 2003 06:50 AM
BoostedB20A
May 11, 2003 03:12 PM
