Very Noob question
Old Mar 11, 2007 | 03:27 PM
meep91si's Avatar
Default Very Noob question
Do I need to run both waste gate and BOV >??? or just one or the other i am leaning more towards BOV but input please.
Old Mar 11, 2007 | 03:34 PM
1Quikgsr's Avatar
you need to run a wastegate also.
Old Mar 11, 2007 | 03:36 PM
BoostedEG6's Avatar
Default Re: (1Quikgsr)
oh boy.....
yes you need both and some research
Old Mar 11, 2007 | 03:38 PM
BoostedEG6's Avatar
Default Re: (BoostedEG6)
http://www.turbobygarrett.com/....html
read everything in there
Old Mar 11, 2007 | 03:52 PM
meep91si's Avatar
Default Re: Very Noob question (meep91si)
lol thankx guys like i said very noob question.
Old Mar 13, 2007 | 01:09 PM
meep91si's Avatar
A couple more questions , you'd think after a month of research i would be able to find all the answers myself. Anyway, here goes.
1. What does it mean to recirulate? ( exhaust )
2. Oil line pressure depend on individual turbo?
3. Would the stock fuel pump in a 91 Si hatch be able to keep up with 310cc injectors? what brands are good? How to order? Do I ask for injectors for a specific brand of vehicle or do i just ask for 310cc for a Civic?
Hoping not to peev anyone off with these questions but hard info to find. I am trying to have all parts and info i need for early May. Running a stock d16a6 with full 2" exhaust intake headder planed and revalved. Plan on 8 psi max for hard runs and 3 for daily driving. We have a weekend called May 2-4 weekend, it's when the drag strip near where i live opens and i would like to run it. help please.
Old Mar 13, 2007 | 01:18 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meep91si &raquo;</TD></TR><TR><TD CLASS="quote">A couple more questions , you'd think after a month of research i would be able to find all the answers myself. Anyway, here goes.
Hoping not to peev anyone off with these questions but hard info to find. I am trying to have all parts and info i need for early May. Running a stock d16a6 with full 2" exhaust intake headder planed and revalved. Plan on 8 psi max for hard runs and 3 for daily driving. We have a weekend called May 2-4 weekend, it's when the drag strip near where i live opens and i would like to run it. help please.</TD></TR></TABLE>
Recirculating the wastegate back into the exhaust means it will be quieter. When the wastegate opens, you will basically be running without a muffler, it will be very loud in other words. Running open wastegate generally nets a few more HP however is considered not worth it on a street car because of the excess noise.
Are you asking if different turbo's require different amounts of oil pressure?
You need to go with a Walbro 255lph pump for a turbo build, as well as larger injectors. Assuming you aren't going to run an FMU.
You may want to consider a larger exhaust as well.
Old Mar 13, 2007 | 01:45 PM
meep91si's Avatar
Default Re: Very Noob question (MooreBoost)
Ok thankx, i knew about havein to upgrade the exhaust also yes i was wondering if ( for example) a T3 needed a different amount of oil pressure than a td04h? No FMU, going to use bigger injectors, hoping to get away with a set of 310cc hide and peek but unsure if it is possible, and turbo edit or ecucontrol.
Old Mar 13, 2007 | 03:24 PM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meep91si &raquo;</TD></TR><TR><TD CLASS="quote">a set of 310cc hide and peek</TD></TR></TABLE>
Old Mar 13, 2007 | 05:54 PM
importheaven's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MooreBoost &raquo;</TD></TR><TR><TD CLASS="quote">Running open wastegate generally nets a few more HP however </TD></TR></TABLE>
really? any links to verify this? i have seen dsm guys welding lil lawnmower, and small boat mufflers to the dump tube to make it quieter..
Old Mar 13, 2007 | 06:20 PM
BoostedEG6's Avatar
lol..... you mean peak and hold
or are your injectors playing peakaboo with you?
Old Mar 13, 2007 | 06:30 PM
MooreBoost's Avatar
Default Re: Very Noob question (importheaven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importheaven &raquo;</TD></TR><TR><TD CLASS="quote">
really? any links to verify this? i have seen dsm guys welding lil lawnmower, and small boat mufflers to the dump tube to make it quieter..</TD></TR></TABLE>
Nope, no link.
You may not read about it much because it really is a minimal difference.
Old Mar 18, 2007 | 05:39 PM
well i actually read quite a bit into this pros and cons of external dump:
pros:
100% elimantes boost creep when mounted on mani (big prob with small turbos/ big exhaust)
cons:
loud as crap
requires mods to dsm mani/ internally gated turbos (weld flapper shut)
mikej94civex
Dec 29, 2009 08:56 PM
Rikter
Jul 1, 2007 06:56 PM
gsr dood
Feb 7, 2006 08:29 PM
4dohs4mohoes
Mar 3, 2004 05:45 AM
