Coolant boils under boost.
Old Mar 9, 2007 | 09:42 AM
PatiKTP's Avatar
Default Coolant boils under boost.
Looking for solution to this problem.
When driving normally (no boost) everything works fine, engine temperature stands still.
When going boost, coolant pressure rises and temperature rises instantly. After that its hard to cool engine with light driving or even at idle.
All coolant hoses seem to be conected properly, no coolant leaks.
Any ideas what can be the problem?
Car is EG5 with swapped B16A2, boosted.
Old Mar 9, 2007 | 09:43 AM
SPOOLINmatt's Avatar
Default Re: Coolant boils under boost. (PatiKTP)
99.9% headgasket.
Old Mar 9, 2007 | 09:57 AM
T3T4H22's Avatar
Default Re: Coolant boils under boost. (SPOOLINmatt)
yep Blown head gasket or the head bolts are stretching under boost.
Old Mar 9, 2007 | 10:41 AM
PatiKTP's Avatar
ok..
can I use ARP head bolts from B18C? will they fit B16A?
Luckilly I have some headgasket lying around...
Old Mar 9, 2007 | 10:54 AM
sp00led's Avatar
Default Re: (PatiKTP)
Also make sure you properly fill your radiator system. You don't want to get any air bubbles in your coolant system.
Old Mar 9, 2007 | 11:00 AM
PatiKTP's Avatar
radiator filled properly, no air bubbles in coolant. double checked that.
might it be some airleak thru throttlebody?
Old Mar 9, 2007 | 11:12 AM
dragnGSR's Avatar
I had the exact same problem. Did every single step of troubleshooting still boiled under boost. The culprit was the headgasket.
Old Mar 9, 2007 | 11:20 AM
willyboyK20's Avatar
Default Re: (dragnGSR)
headgasket, I had the same problem
rx7_
Mar 8, 2010 08:52 AM
aho
Dec 15, 2007 09:24 PM
turbotime
Oct 13, 2005 10:49 AM
Alstare
Jul 27, 2004 04:06 AM
whagkangmakulet
Nov 21, 2001 06:19 PM
