a turbo question
Old Mar 9, 2007 | 04:48 PM
zenon8890's Avatar
Default a turbo question
hello, i have a d15b vtec on my 88 rex and i'm running a custom turbo kit. i got the turbo from a subaru impreza 98 it has IHI on it, i guess u can consider it as a small turbo right, it spool very fast and very early, i'm having a serious wheel spinning problem cuz of that.
i'm getting a mitsubishi td05h turbo
if i bought a bigger turbo would that problem go?!
or less wheel spinning?!
plz dont say lsd or slicks i'm talking about street car.
Old Mar 9, 2007 | 04:51 PM
ILcrxsi1's Avatar
I tell doctors what to do
Default Re: a turbo question (zenon8890)
are you using the si trans?
Old Mar 9, 2007 | 05:03 PM
89EF_Turbo's Avatar
Default Re: a turbo question (ILcrxsi1)
The IHI you're talking about is a tdo4. They have a faster spool time, or threshold, than a 14b does with a tdo5h wheel in the 6cm^2 housing, but not much faster. You could try swapping a 7cm^2 exhaust housing from an evo3 16g to slow down your spool on the 14b, more than likely would help lessen your wheelspin quite a bit until you hit threshold.
Old Mar 9, 2007 | 05:07 PM
zenon8890's Avatar
i dont know if i have SI tranny or not cuz i bought it from a junk yard, but it was from a d15b carburated engine, my passenger wheel spins crazily than the other one
Old Mar 9, 2007 | 05:15 PM
89EF_Turbo's Avatar
Default Re: (zenon8890)
More than likely it's just a standard dx trans. The wheelspin is due to an open differential, meaning no lsd in the trans. No biggie for a daily driver.
Old Mar 9, 2007 | 05:20 PM
zenon8890's Avatar
actually it does, if i want to change lanes to pass a car and try to push some gas, it start spinning to, my tires are new with 16' rims. i'm running 7psi but i'm lowering it to 4psi due to that problem
Old Mar 9, 2007 | 05:22 PM
ILcrxsi1's Avatar
what kind of tires?
Old Mar 9, 2007 | 05:25 PM
89EF_Turbo's Avatar
Hmm, your turbo must spool up very fast then on your setup. You could try swapping either to a larger a/r exhaust housing, or to a turbo with a larger a/r. That way when you hit that boost threshold it'll be higher in the rpm range where you already have some traction. Or you have a very poor quality of tire.
Old Mar 10, 2007 | 07:06 AM
zenon8890's Avatar
thats it i'm getting a bigger turbo, td05h i guess from an evo 6, its a good turbo, but should i keep running at 7 psi or lower it?!
Old Mar 10, 2007 | 07:08 AM
zenon8890's Avatar
Default Re: (89EF_Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89EF_Turbo &raquo;</TD></TR><TR><TD CLASS="quote"> Or you have a very poor quality of tire.</TD></TR></TABLE>
maybe that and poor quality of roads too
Old Mar 10, 2007 | 09:23 AM
b18sihatch's Avatar
i would go with a traction bar, or a lsd transmission from the d15b motor, i believe they have a lsd.
honestly it dounds like the problem isnt the setup but lack of traction control (obviously) however if the turbo spools really quickly, and the setup seems strout, i wouldnt go in and start adjusting thnigs to alter the spool or power.
however i would look into lsd,traction bar,better tires, and a streety car can have a lsd, esp if it is needed in a wheel spin application like yours
zakura R
Jun 19, 2010 10:44 AM
silver99hatch
Jan 2, 2006 03:30 PM
eg:R
Jul 28, 2005 05:32 PM
mrx
Apr 20, 2005 07:56 AM
Loco Honkey
Jan 20, 2003 07:17 AM
