P72 OIL PAN
Old Mar 11, 2007 | 05:34 PM
Custom Rex's Avatar
Default P72 OIL PAN
will a p72 oil pan be compatible with my b16a2 block?
have searched and had mixed reviews and don't want any problems with fitment or pick up placement. thanks
Old Mar 11, 2007 | 08:17 PM
stockb18c's Avatar
yes
Old Mar 11, 2007 | 08:50 PM
s2kdre's Avatar
Default Re: (stockb18c)
yes
Old Mar 11, 2007 | 11:04 PM
riceball777's Avatar
Default Re: P72 OIL PAN (Custom Rex)
you can use a p72 pan with any b seris motor but you cant use a b16/ls pan for a gsr or itr motor
Old Mar 12, 2007 | 06:56 AM
atec's Avatar
yes (x3)
Old Mar 12, 2007 | 12:56 PM
IntegraGSR-Turbo's Avatar
Default Re: P72 OIL PAN (atec)
if your running vtec...you need the p72..
Old Mar 12, 2007 | 01:09 PM
Default Re: P72 OIL PAN (IntegraGSR-Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraGSR-Turbo &raquo;</TD></TR><TR><TD CLASS="quote">if your running vtec...you need the p72..</TD></TR></TABLE>
very incorrect
the b16 does not have a block girdle and uses the same ol pan as the ls and b20 motors but they can also use the p72 oil pan,
the motors with block girdles like the gsr and itr motors must use the p72 oil pan and the b16 pan will not work
Old Mar 12, 2007 | 04:15 PM
PHDZINE's Avatar
Default Re: P72 OIL PAN (riceball777)
You can physically fit the P72 oil pan on a B16 and the B18A/B but I wouldn't advise it due to the oil pick-up on the B16 and B18A/B sitting a little higher due to not having the girdle. The pick-up sitting higher might not supply the full amount of oil thats in the oil pan due to not being closer to the bottom.
Old Mar 12, 2007 | 04:54 PM
Custom Rex's Avatar
Default Re: P72 OIL PAN (PHDZINE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHDZINE &raquo;</TD></TR><TR><TD CLASS="quote">You can physically fit the P72 oil pan on a B16 and the B18A/B but I wouldn't advise it due to the oil pick-up on the B16 and B18A/B sitting a little higher due to not having the girdle. The pick-up sitting higher might not supply the full amount of oil thats in the oil pan due to not being closer to the bottom.</TD></TR></TABLE>
again mixed reviews, ill have to try myself and see...
Old Mar 12, 2007 | 04:59 PM
TODAwhore's Avatar
x2nd that..
m4xwellmurd3r
Mar 31, 2014 05:43 AM
ShortbusEK
Apr 5, 2008 02:51 PM
Boosted_B_Series
Dec 25, 2006 05:06 PM
Hoffy
Apr 22, 2005 04:38 PM
eRACING
Nov 23, 2004 03:46 AM
