Head Bolt Question
Old Mar 15, 2007 | 10:20 AM
j-spec_cc2's Avatar
Default Head Bolt Question
I posted this the TL forum, but thought maybe someone would stumble across it here and be able to help me out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-spec_cc2 in Acura TL Forum &raquo;</TD></TR><TR><TD CLASS="quote">
I have a 94 Vigor that I need to change the head on. Pretty much everywhere I've read states that you shouldn't reuse cylinder head bolts because of bolt stretch. Ok, so I called Acura trying to order a set of head bolts and they said I'm looking at ~$15 for the 11 bolts and ~$18 for the longer bolt. Thats about ~$200 for the kit.
I was wondering if it was possible that I could cross reference my bolt specs with another vehicles (possible f/h/k?) and pick up the bolt/stud kit for that.
The only specs i was able to get were:
11 bolts - 12 x 146mm
1 bolt - 12 x 182mm
Now, I'm ***uming that those numbers are the socket size and the bolt length respectively. I'm thinking i'd also need to know the thread pitch for those (and the other) bolts/studs as well, but i'm hoping Honda uses the same pitch for all their head bolts.
If anyone can give me some help or insight, that would be greatly appreciated.
Thanks.
Old Mar 15, 2007 | 11:12 AM
Boilermaker1's Avatar
Thats kind of an incomplete bolt spec. you're missing the thread pitch.
Its a 12mm thread, unknown pitch (1.5 is standard IIRC) thats either 146 or 182mm long.
Old Mar 16, 2007 | 06:08 AM
j-spec_cc2's Avatar
is it safe for me to assume that IIRC = If I Remember Correctly????
morning bump
notnilc20
May 14, 2011 12:09 AM
j-spec_cc2
Mar 16, 2007 06:08 AM
CRX-Noob
11
Jul 7, 2006 10:43 PM
1bar
May 12, 2004 10:33 PM
