spooling issues??
Old Mar 13, 2007 | 06:07 PM
eshlil's Avatar
Default spooling issues??
my setup
100% stock gsr motor
peakboost ramhorn manifold
xs power waste gate (going to get a tial wastegate)
50mm tial bov
450 dsm injectors
garret t3/t4 turbo a/r 60
walbro 255 lph
3inch downpipe going to 2.5 inch exhaust with high flow cat
stock intake manifold
tuned on crome
on 4.5 pounds of boost (have a leak somewhere going to go for a retune after its fixed and boost 8psi)
making 221 hp and 165 torque I don't see boost until after 5500 rpm
My questions are what can I do to make the turbo spool faster? When I build the motor and say im able to boost 18 pounds will the spool time get faster?
thanks
chris
Old Mar 13, 2007 | 06:12 PM
katoeh2o's Avatar
Default Re: spooling issues?? (eshlil)
Run a test pipe and 3inch exaust. And fix your boost leak.
kyden's Avatar
i think the big problem is that you're leaking boost, thats why its taking so long to spool.
Old Mar 13, 2007 | 06:20 PM
eshlil's Avatar
Default Re: spooling issues?? (katoeh2o)
Would I spool alot quicker with a 3inch exhaust?
Old Mar 14, 2007 | 10:33 AM
katoeh2o's Avatar
Not alot quicker your 2.5 exaust is ok. The boost leak is your main problem.
Old Mar 16, 2007 | 03:02 PM
eshlil's Avatar
Another question a t3/t4 60 compressor side and 63 exhaust size where should it spool at?
thanks again
chris
Old Mar 16, 2007 | 03:51 PM
Schister66's Avatar
Man U FTW
I'd be willing to bet that the problem is your Chinese wastegate...they tend to leak
eshlil
Mar 17, 2007 11:44 AM
boostdummy
Oct 28, 2005 08:37 PM
b18cEF9
Jul 31, 2005 10:56 AM
VisualAutoMotoring
Apr 3, 2003 06:40 PM
