10:5:1 to much for boost?
Old Mar 13, 2007 | 01:52 PM
indy90turbocrx's Avatar
Default 10:5:1 to much for boost?
I just picked up a b18a1 block with JE 10:5:1 pistons and eagle rods. I was thinking on getting some different pistons in 9:1 or somewhere in that range. I planned on tearing it down and having the block looked at and add some new bearings and rings at the very least. The block has been sitting around for a year. The guy got it off his friend who put 15000 miles on it then parted the head and block out. From what I understand the block was sprayed a few times. This block will be going in my DD crx. I plan to run no more then 350hp. Should I use them or no?
Old Mar 13, 2007 | 02:18 PM
JSPECSIR's Avatar
Default Re: 10:5:1 to much for boost? (indy90turbocrx)
my oem comp. is 10.4:1 im boosted. you should be fine. its all in the tuning.
Old Mar 13, 2007 | 02:47 PM
DeadVet's Avatar
Default Re: 10:5:1 to much for boost? (JSPECSIR)
Tuning is key. I have boosted 11.0:1 at 12 psi with no problems.
Old Mar 13, 2007 | 03:38 PM
jelcivic's Avatar
Default Re: 10:5:1 to much for boost? (1TurboHatch)
you have the answer. find a good tuner. my friend ran 13lbs on the stock comp on his GSR and rolled out around 320whp.
Old Mar 13, 2007 | 04:26 PM
ownage's Avatar
you should b fine then again if you want 350 hp. lower compression would be better
B16afmaxt
Nov 11, 2009 04:27 PM
killacam661
Nov 26, 2007 12:35 PM
ORANGE EF
May 25, 2006 02:21 PM
jdm'dc2sc61
Apr 9, 2005 02:13 PM
B18CHatch
Oct 18, 2001 03:06 PM
