Missfireing at full boost.
Old Mar 12, 2007 | 05:02 PM
Fo-Do Fanatic's Avatar
Default Missfireing at full boost.
So me and my buddy just changed his wastegate spring from a 7psi spring to 10psi. When he got the car tuned it was tuned for 10 psi. When the car had the 7psi spring in it, it was popping, mis-firing, or anythign at all. now that we put the 10psi spring it does. it didn't do this when the car was first tuned.
any one know whats wrong??
Old Mar 12, 2007 | 05:09 PM
97grnrs's Avatar
Default Re: Missfireing at full boost. (b00sted-Hatch)
prob not enough fuel or too much timing.. that will lead to major damage if u keep making it "pop"
Old Mar 12, 2007 | 05:10 PM
Default Re: Missfireing at full boost. (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">prob not enough fuel or too much timing.. that will lead to major damage if u keep making it "pop" </TD></TR></TABLE>
how would it not have enough fuel when it was first tuned at 10psi and ran just fine then? but when he got a different wastegate it had a 7psi spring in it and he ran that for a while and today we just changed it back to a 10psi spring...
Old Mar 12, 2007 | 05:24 PM
ham's Avatar
ham
how was it tuned for 10psi if you had a 7psi spring in it? if it was tuned at 10psi, why would he put a 7psi spring in it?
maybe the boost cut was set at 10psi?
Old Mar 12, 2007 | 05:36 PM
Default Re: Missfireing at full boost. (ham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">how was it tuned for 10psi if you had a 7psi spring in it? if it was tuned at 10psi, why would he put a 7psi spring in it?
maybe the boost cut was set at 10psi?</TD></TR></TABLE>
my buddy had an innovative wastegate with a 10psi spring, but the studs that were on it to hold it to the manifold broke SEVERAL times. he then bought a tial 38mm with a 7psi spring off craigslist and he ran that for a while, now i just changed the spring to a 10psi spring in the tial.
understand now? sorry for being unclear
Old Mar 12, 2007 | 05:52 PM
DaveF's Avatar
try some new plugs and see what happens. also when was the last time the injectors were cleaned and flowed ?
Old Mar 12, 2007 | 05:53 PM
Default Re: Missfireing at full boost. (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">try some new plugs and see what happens. also when was the last time the injectors were cleaned and flowed ?
injectors have never been clean. how do you recommend that we clean them? ill tel him to get some plugs..
Old Mar 12, 2007 | 06:09 PM
boosted k20's Avatar
try gapping the plugs or changing them. also get a wideband on the car to see if its a fuel problem. with the 10 lb spring, ur probably seeing boost come in a bit quicker, so the car is probably running in some parts of the maps that it wasnt tuned for.... even though u had a 10 lb spring in before, the car might be boosting quicker with the tial gate
ham's Avatar
ham
are you sure the innovative wastegate was running 10psi? is the tial running a little bit more?
Old Mar 12, 2007 | 06:11 PM
97grnrs's Avatar
i still say too much timing/ not enough fuel.. be careful driving it like that till u fix. ive seen too many motors blown cause of the magic " pop" noise at WOT
Old Mar 12, 2007 | 06:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">are you sure the innovative wastegate was running 10psi? is the tial running a little bit more?</TD></TR></TABLE>
yes im sure. we tested 2 boost gauges. my brothers defi and my buddies autometer. both said EXACTLY 10psi just like its saying right now.
Old Mar 12, 2007 | 07:03 PM
Chiovnidca's Avatar
What plugs? What gap?
Old Mar 12, 2007 | 07:11 PM
Default Re: Missfireing at full boost. (Chiovnidca)
the plugs haven't been changed since he went boost.
he's getting new plugs tomorrow. what kind should he get? what gap?
Old Mar 12, 2007 | 08:24 PM
Old Mar 12, 2007 | 09:25 PM
stockb18c's Avatar
gap the plugs around .025 to .030 see how that does
Old Mar 12, 2007 | 09:41 PM
Default Re: (stockb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockb18c &raquo;</TD></TR><TR><TD CLASS="quote">gap the plugs around .025 to .030 see how that does </TD></TR></TABLE>
i figured as much as .25 gap but what plugs? like a step or 2 cooler?
Old Mar 12, 2007 | 11:39 PM
bboysakeq4's Avatar
Oh yeah and Im spittin' lots of fuel too....this is my car we're talking about here! it almost seems like Im running rich now...
ctownintegra
Jul 9, 2008 02:41 AM
tagperformance
Jun 29, 2007 03:33 PM
Lucky_Smurf
Sep 22, 2004 06:31 AM
9deuce9rr
Mar 28, 2004 12:32 PM
Short Round
Nov 12, 2003 10:16 PM
