Max bore for stock gsr sleeve?
I need to know if I can boost my motor... around 9.5:1 comp and 82mm bore with the stock pistons, rods and bore...
Re: (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 »</TD></TR><TR><TD CLASS="quote">I wouldnt go over 81.5 on stock sleeves with boost</TD></TR></TABLE>
Re: (Dual Cam Racing)
Thanks guys- And that sucks.... I think around 12psi would be okay but no chance to tune 20+ and race gas..
Re: (b18sihatch)
as long as you can control the combustion, IMO you will be fine.
Just remember, all it takes is 1 thing to go wrong (misfire, bad tank of gas, mis adjusted timing, bad water pump, bad fuel pump/fuel injectors etc...) and BOOM
so just make sure EVERYTHING is in working order.
Re: Max bore for stock gsr sleeve? (black99x)
If you go 82mm on stock sleeves with boost you will be sending that block out for resleeving sooner than you expected
