downpipe hitting motor mount
Old Mar 10, 2007 | 04:08 PM
blinger's Avatar
Default downpipe hitting motor mount
car is a 90 hatch .. the downpipe is from an EG. the motor is a d15b2. The downpipe is hitting off of the front motor mount so I can't get it bolted on at all.. Is there anything I can do without doing a ton of welding to the dp besides buying a new one?
Old Mar 10, 2007 | 04:17 PM
Schister66's Avatar
Man U FTW
pictures?
Old Mar 10, 2007 | 04:40 PM
Civicman86's Avatar
Default Re: (Schister66)
how close is it hitting. I know I had to shave a little webbing off my block. Also when I put the turbo on the downpipe I had to make sure the turbo was turned as far as it could in the small clearances of the manfold flange (hard to explain, but if the bolts are loose there is some play wher the bolts are smaller than the holes in the manifold flange).
Old Mar 11, 2007 | 10:34 AM
blinger's Avatar
no pics yet ... I'll see if I can get some later today tho. I don't think it is hitting by a lot but its still a problem. Is notching the motor mount a bad idea?
Old Mar 12, 2007 | 04:36 PM
blinger's Avatar
Default Re: (blinger)
bump for notching motor mount question
Old Mar 16, 2007 | 07:54 AM
blinger's Avatar
ended up having to redo the entire downpipe instead. there was no way to get it to work even if I would have cut the motor mount
92siRome
19
Jul 21, 2015 04:34 AM
ItsMikeBABY
Jun 21, 2008 03:17 PM
218luder
May 23, 2008 02:25 PM
ShadyBAB
Dec 29, 2005 04:19 PM
94integragsr
Jul 13, 2005 07:21 PM
