10.2:1 to 9:1 difference
Old Mar 15, 2007 | 04:47 AM
flangemastermike's Avatar
Default 10.2:1 to 9:1 difference
was running a stock b16a2 at 8psi, but damaged one of the pistons and had a set of gsr pistons which i made fit and now my compression ratio is 9:1. i can feel the throttle response is slower but my question is would i have to run 10psi to make the same power as before ?.
Old Mar 15, 2007 | 04:52 AM
JoePSI's Avatar
Default Re: 10.2:1 to 9:1 difference (flangemastermike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flangemastermike &raquo;</TD></TR><TR><TD CLASS="quote">was running a stock b16a2 at 8psi, but damaged one of the pistons and had a set of gsr pistons which i made fit and now my compression ratio is 9:1. i can feel the throttle response is slower but my question is would i have to run 10psi to make the same power as before ?. </TD></TR></TABLE>
You would have to run a higher psi to compensate for the lower compression but I dont know where you got 2psi more from.
Old Mar 15, 2007 | 06:09 AM
it was a guess , any one got any experiance with this ?
Old Mar 15, 2007 | 03:30 PM
TheShodan's Avatar
Moderator
Default Re: (flangemastermike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flangemastermike &raquo;</TD></TR><TR><TD CLASS="quote">it was a guess , any one got any experiance with this ?</TD></TR></TABLE>
It's really more about acceleration when it comes to staying at a relatively higher compression than a lower compression. What you're feeling is the OFF-BOOST effects of the lower static compression. Remember this, the actual power output doesn't change whether you have a low static compression or a high one. IT does take a bit more "boost" to get the same hp, but it does not change what the horsepower itself will be.
Old Mar 15, 2007 | 05:10 PM
bigbadboy's Avatar
you lost 10hp ever point of compression is 10 hp less. look it up its been tested
Old Mar 15, 2007 | 06:57 PM
HiProfile's Avatar
Default Re: (bigbadboy)
I'm assuming it wasn't retuned after the fix. Running less compression means you can run more timing per lb of boost, and that you need to run a little more boost for the same power. Amount of boost is really irrelavant, its the power ceiling of the ringlands on the pistons you have. Cast pistons aren't all that great, regardless.
Old Mar 15, 2007 | 07:09 PM
im just runnin this setup until my b18 is ready. is 1 point of Compression ratio 0.1? just doesnt feel as fast as a stock b16.
Old Mar 15, 2007 | 07:22 PM
GetawayInMoscow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy &raquo;</TD></TR><TR><TD CLASS="quote">you lost 10hp ever point of compression is 10 hp less. look it up its been tested</TD></TR></TABLE>
Hmm interesting, B16's do gain about 10whp from CTR pistons, which is about a 1.0:1 jump in compression.
careawholelot
Aug 29, 2005 07:42 AM
Quade
Apr 5, 2005 03:12 PM
ochsy03
Apr 4, 2005 05:04 PM
dEtSoOb
Mar 19, 2004 12:05 PM
turbo Si
Jun 26, 2002 04:28 AM
