Does PSI=WHP?
Old Mar 13, 2007 | 07:14 AM
lsvtec225's Avatar
Default Does PSI=WHP?
Alright this is my question.
Lets compare a GT28 and a GT32!!!
On two exact same motor setups at 10psi do these two setups make the same amout of power.
I understand that smaller turbos spool quicker, and bigger turbos can push more cfm's. but if your only going to run say 8-12 psi is it smarter to get the smallest turbo possible (for the better powerband) that still meets your power goal!!
thanks
Old Mar 13, 2007 | 07:19 AM
mike1114's Avatar
Default Re: Does PSI=WHP? (lsvtec225)
no psi does not equal horesepower
larger turbo will make more horsepower at same boost level because it is flowing more air per minute for the most part. Efficiency and heat play key factors also.
For a daily driver, in my opinion, I like a smaller turbo so it will spool faster and be more fun daily driving (better powerband), for a little sacrifice of top end.
D series I would get Gt28R (pick your trim)
B series I would get GT30R (smallest trim)
again, these are my opinions.
Modified by mike1114 at 4:45 PM 3/13/2007
Old Mar 13, 2007 | 07:21 AM
honda_joe's Avatar
CFM vs PSI
https://honda-tech.com/zerothread?id=1055905
Old Mar 13, 2007 | 07:42 AM
TIGboy's Avatar
Default Re: Does PSI=WHP? (honda_joe)
^exactly
Old Mar 13, 2007 | 07:48 AM
lsvtec225's Avatar
Wow i just finished ready the other forums!!
Did you see the graph of the GT28Rs vs Gt3071. Im looking for similar results, do you think i could get them on a B17 with GT28Rs with .63 ar
Old Mar 13, 2007 | 08:03 AM
b18sihatch's Avatar
Default Re: (lsvtec225)
i wouldnt get anything less than the gt3076r for a b series
Old Mar 13, 2007 | 08:08 AM
lsvtec225's Avatar
My set up will be for Road Racing and daily driving, i think the biggest i'd go would be a Gt2871 on 9 psi
bloodydc2
Apr 15, 2006 06:23 PM
ted
Dec 16, 2004 03:08 PM
lazy bum shaughn
Jan 28, 2003 05:27 AM
Jesse H
Nov 15, 2001 12:32 PM
