Cleaning out the engine
if you decide to do that first off make sure you cover all your electrical and air intake components so that they don't get wet.. and also make sure your motor is completely cold (so you don't warp or crack anything)... personally I haven't really detailed my motor beyond using some simple green...
If you do it right you're ok. I used to do that when I worked as a detailer.
Cover the fuseboxes, dizzy, spark plugs, and everything else electrical.
well I've seen people do it.. I just don't do it myself... if you cover your electrical components and your air intake so they don't get wet you might be OK... I wouldn't be hosing off cold water on a hot motor.. you don't want to crack anything or warp anything... but personally I don't really detail my motor beyond wiping it down a little (lazy)..
I just spray mine with engine degreaser, let sit then hose it down.
It's also important to let the water run in a trickle so it doesn't splash all over the place.
Would I be an idiot to clean out my engine bay area by spraying it out with a hose?
madcrossover
10
May 24, 2007 02:24 PM
