crv block
Old Aug 14, 2002 | 09:28 PM
wykid13sec Teg's Avatar
Default crv block
will a 94 gsr tranny and head bolt up to a crv block
Old Aug 14, 2002 | 09:35 PM
lsteggy's Avatar
Default Re: crv block (mookie)
yes the tranny will hook up and the head will hook up but you have to tap the block and run the oil lines look here http://absolutevtec.websitegalaxy.com/lsvtec.html
Old Aug 20, 2002 | 11:39 AM
Default Re: ls-vtec
i have a 94 gsr but the motor got hydrolock and crank the block,so i put a ls motor in it for the time being till i finsh building my gsr,but the ls is not cuting.
So do you think if i build the bottom end rods piston could i rev8k,and would it be stronger than a gsr
Old Aug 22, 2002 | 01:12 AM
Default Re: crv block (lsteggy)
do u think a lsvetc with a gsr head and tranny would be stronger than a gsr.
do you know any that sells motors
Old Aug 22, 2002 | 05:32 AM
DA666's Avatar
hondamotorsonline.com
cheap...but let me know if you guys know of a better cheaper site...or place
i am goin with the b20 ls head combo....mad torque for boost baby!!!
Old Aug 22, 2002 | 09:17 AM
dohcsideSi's Avatar
SEARCH!!!
Old Aug 22, 2002 | 01:35 PM
MugenGTR's Avatar
Default Re: crv block (dohcsideSi)
the tranny will bolt up, i have a ls tranny bolted to my b20, it's fine. the head like sum1 else said needs to be modded to fit, nuthin TOO hard though, good luck! motor is gonna be krazy!
Old Aug 22, 2002 | 05:08 PM
Default lsvtec (MugenGTR)
do u think a ls vtec would be stronger than gsr or as strong with a build low end gsr head and tranny rod and piston.
Honda_Fanatic
Feb 22, 2011 04:17 PM
integra206
Northwest (Sales)
Oct 23, 2008 08:09 AM
WhaznSiR
Jul 11, 2005 06:18 PM
Sliced Beard
Feb 4, 2004 08:49 PM
