Camber kits
Old Aug 13, 2002 | 03:20 PM
AxznBlitz's Avatar
Default Camber kits
Hey
I drive a 2000 acura integra GS and was wondering how hard is it to install front and rear camber kits? what is the process involved? do i need to take out my suspension again?
how hard is it to adjust the camber kit? will an alignment place adust them for me when i get the car aligned??
thanks for any info
Old Aug 13, 2002 | 04:05 PM
shattergsr's Avatar
Default Re: Camber kits (AxznBlitz)
Hey
thanks for any info
an alignment place will adjust your camber for you, if they CAN. You can't change front camber on integra's so if you had a camber kit put on, they would adjust as necessary.
Old Aug 13, 2002 | 06:05 PM
frogsr's Avatar
Default Re: Camber kits (shattergsr)
how is it that a camber kit would not affect camber on the front of an integra?
Old Aug 13, 2002 | 07:39 PM
vteg's Avatar
New User
Installing camber kits will take about 30 minutes per corner. You will need to remove the strut bar and upper control arm in the front. The back can be done in less time than the front.
An alignment shop will adjust it for you. Ask them if they do lowered cars with camber correction kits before visiting of course.
Old Aug 13, 2002 | 08:22 PM
slomofo's Avatar
GDD Member
You change the upper ball joints, so you're wrong.
Don't waste your money on a camber kit, the front usually doesn't go bad and the rear usually does. If you add washers to the bolt that holds on the rear upper control arm, you can add positive camber, then take it to an alignment shop to set it to proper caster.
Old Aug 13, 2002 | 09:15 PM
AxznBlitz's Avatar
Default Re: Camber kits (slomofo)
Hey
the thing is i lowered my integra with eibach prokit springs using koni yellows and i have more negative camber up front then the rears.....it seems to be opposite for me. So installing the front camber kit is hard? i have to take out the front suspension??
btw i am planning on using ingalls camber kits if that helps....
thanks
[Modified by AxznBlitz, 6:16 AM 8/14/2002]
doubleshotz
Suspension & Brakes
Nov 2, 2007 05:01 PM
Elbowpunk
Feb 11, 2007 07:22 PM
mattdenali
Suspension & Brakes
May 26, 2005 09:21 PM
fafsa
Apr 6, 2005 03:41 PM
